Chris, I would pull the pan back off and install that stop, can you imagine the frustration of priming the motor and pulling the drill out only to realize the oil shaft is laying in the bottom of the oil pan after you installed the motor. Don't even second guess this one...
The washer stop goes on the top of the shaft, not near the oil pump, it stops the shaft from being pulled out during distributor removal. The oil pump needs removed and the oil pump shaft needs to be installed with the stop washer first, THEN reinstall the oil pump lining up shaft to oil pump drive, AND DON,T FORGET THE OIL PUMP TO BLOCK GASKET AND THE PICKUP TO OIL PUMP GASKET... Use locktite sealant too, can't remember if it's the red or blue but use that which is oil resistant.
_________________ 4400lb 90 MarkVII, KB Blowzilla2.2, 333ci Boss block, A9l BE/EA GUFB, AFX Wideband, PLX EGT&Boost modules, 80mmTB, C&L 85mm Maf, 4" fender CAI, 48lb inj. 255 lph, AFR165/Nos exhaust ports, 1.6r.r, Cammotion cam 220/220 278/278 579/579 114, Meth inj. 50/50 18gph, 175hp NOS Dry, Ported stock lower 265avg@28", 1 3/4'' shorties, 2800 PI Convertor, 3.73, Hyfire CD IGN, 200 amp alt, 306ci old motor best 1.560 60' 7.40@92 11.63@117 with 125nos on MT radials.
Last edited by markedforlife on Thu May 10, 2012 12:52 am, edited 3 times in total.
