It is currently Fri May 24, 2013 5:42 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: data logging stops
PostPosted: Sun Sep 04, 2011 10:17 pm
Offline
I recently purchased/installed a Moates QH and Binary Editor. I'm on BE 2010 build 32, installed on Windows 7 pro x64.
Every time I turn on the data logging, I get 7-10 seconds in and it stops. I've dug through the search features and ran across several suggestions to address the issue.
So far:
loaded the driver for the QH per the instructions in the "getting connected" guide.
set up the QH using mode 2 slot 2
copied the files from c:\program files(x86)\binaryeditor\drivers\amd64 to c:\windows\system32
modified registry - hklm\system\currentcontrolset\services\gtdibus\parameters\RetryResetCount changed from 50-200 (decimal)
tried several usb latency settings (2/4/5/8/16)
Another strange thing to note, when I first installed the drivers, I installed them on "usb serial port" in the device manager. Once the driver install is complete, I end up with a "quarterhorse" device, but I still have a "usb serial port" under Other Devices.
Any ideas would be greatly appreciated. I'm hoping it's something obvious that I'm just missing.
_________________
Car Info
Top
 Profile
 Post subject: Re: data logging stops
PostPosted: Mon Sep 05, 2011 9:00 am
Offline
Professional Tuner/Shop Owner
Clint or I could remote in and fix for you...
_________________
Authorized Binary Editor / Moates / TwEECer / SCT Dealer /Diablosport / Drewtech
Land and Sea chassis dyno
1995 Cobra, 408, sold...
Top
 Profile
PostPosted: Mon Sep 05, 2011 12:17 pm
Offline
Remote support would be great.
Also, I'm an IT guy by day, in case it's something that could be explained.
Either way, I would appreciate the help :biggrin:
_________________
Car Info
Top
 Profile
PostPosted: Mon Sep 05, 2011 5:46 pm
Offline
give me a shout in the morning.
Regards,
Adam
_________________
Top
 Profile
PostPosted: Tue Sep 06, 2011 9:20 pm
Offline
Just for reference, in case anyone runs across the same issue:
We needed to add a second driver on the "usb serial port" that wasn't recognized. Use the same quarterhorse.inf, chose FTDI as manufacturer, then scroll down to "usb serial port". There are two, I believe we chose the top one.
Thanks for the help Adam!
_________________
Car Info
Top
 Profile
Search for:
Jump to:
