by Cougar5.0 on Tue Apr 07, 2009 7:09 pm
cgrey8 wrote:The WB will detect this as running lean. But rev limiters don't just pull fuel across the board. First stage rev limiters randomly misfire injectors (averaging to about every other injector). So the cylinders that do fire, fire with their full compliment of fuel and thus they don't run lean. And obviously the cylinders that don't get an injector fire, don't get any fuel to burn. This is why the rev limiters are safe for the engine. However from the WB's standpoint, it see's a massive amount of oxygen and reports the condition as it see's it...lean. Now 2nd stage rev limiters will pull all fuel. So if pulling 1/2 the fuel doesn't get the RPMs down, pulling all of the fuel most definitely will.
What's disturbing though is the 16 LAMBSE. The GUFx strats don't do that. But it is quite possible the newer strats do? But for what purpose, I have no clue because it sure makes things look like the cylinders that did fire, fired lean and were commanded to do so.
In GUFB the rev limiter
does just pull fuel across the board - see re-post of the description and logic below. Alternate firing of injectors is only a SPEED LIMITER, not a rev limiter. It appears that CBAZA is a full-cut limiter too, though there is a mention of using Stage 2 (alternate injector firing) in a "mid gear stage 2 rev limit" in CRAI8, though there's no way to tell if CBAZA used this and the parameters are not visible in CBAZA if it is used.
5L KB blown (10 psi), AFR 165's, C&L 80mm w/Tuner Tube, XE270HR cam, TKO500, Eaton Trutrac rear, 42# injected 20th Anniversary Cougar
11.96 @ 118MPH
3700 lb
A9L, TwEEcer R/T 1.30B3, EEC Analyzer, Bin Editor, LM-1 WB.
