Moderators: cgrey8, Jon 94GT, 2Shaker
Rex wrote:Maybe there is a reason no one uses TwEECer.
If you don't want to pay for the tune you're probably stuck if you insist on TwEECer.
Why can't you do it yourself with the dyno folks if you know TwEECer? The tuner should be able to tell you what needs to be done.
BobCat wrote:The reason most guys don't use the TwEECer is the same reason most don't use the Moates hardware either...... SCT, Diablo, and Sniper all have a click click tune setup that works half assed for even those with limited or no knowledge of what they are doing and it take all of 2min to write a tune from scratch.
I can't count the number of cars that I've had come in that were complete "value file" tunes that the customer paid "custom" tune prices..... it all became very obvious about 2yrs ago when the OBD-II testing changed and all of the "value file" tunes wouldn't pass emissions.
cgrey8 wrote:What happened that they wouldn't pass emissions? Was it something technical the emission computers were looking for in the EEC or were the engines simply failing sniff tests?
cgrey8 wrote:I've often thought it would be nice if the code could be hacked to actually disable all those things in function, but report that all was active and working just fine to any OBD-II device that asks about them.
