Datalog for ACT and ECT reading zero
Moderators: cgrey8, Jon 94GT, 2Shaker
Postby Diabolic » Wed Feb 03, 2010 2:23 pm
My ACT and ECT show zero when trying to datlog my 93 Lightning. I have the Qtr Horse 1.6 with the BE software. I have been talking to Adam Marrer about this, but instead of resting the burden on him only I'm asking publicly. I was datlogging fine and then it froze on ACT of 82º and ECT of 132. Now when I start to datalog they both read zero. I have tried:
1) a new strategy file,
2) new C3P2 calibration,
3) a new datalog payload.
4) I have tried clearing all the tunes in Pos 2 and relaoding 8 new ones.
5)running a degbug file
6)Verified that both sensors are getting a 5 volt refrence signal
7)Verified that both sensors are functioning correctly with a multimeter
8)verified that the ECT is sending a signal all the way back to the ECM with my multimeter
Truck pulls up no codes except for 511 Prom failure
The truck runs perfect otherwise and will datalog everyrthing else I command it to. I am really stumped. Anyone have other ideas?
Diabolic
Re: Datalog for ACT and ECT reading zero
Postby Chucko » Wed Feb 03, 2010 3:55 pm
Just a SWAG... have you tried pulling the battery off the QH to let it reset? Good luck.
'89 LX 5.0, Crane 2040, Pro-M 80 mm, 65 mm TB, ported stock intake & E7TE heads, 24 lb injs., JBA shortys, cat X-pipe, A3M1 w/Moates Quarterhorse, BE & EA, close ratio T5Z, 3.55 rear
Chucko
Postby Diabolic » Wed Feb 03, 2010 5:47 pm
I have not tried that. What all will that effect with my tunes and other things. Will I need to reinstall the qtr horse or anything like that? Anyone ever had to do this before?
Diabolic
Postby EDS50 » Wed Feb 03, 2010 7:14 pm
You can try to check your payload to make sure you have them enabled in you datalogging screen and to make sure the levels are selected under the settings tab.
1989 GT - 5.0, TFS Trackheat Heads & Intake, TFS Stage 1 Cam, FRPP 1.6 RR, FRPP 65mm TB, C&L 73mm MAF/Stock elec. & airbox, FRPP 24#s, 255 lph pump, Mac 1-3/4 shorties/2-1/2" Exhaust/Flow 44's, T-5, 4.10-31 spline, MSD 6AL, A9L w/X3Z.bin, Moates QH v1.6, BE, EA, Innovate LC-1/XD-16.
1992 LX -DSS Renegade 317, Lentech Strip Terminator AOD, C&L 80mm, FRPP 30#'s, Crane Ignition and Digital Engine Controller, Barry Grant EGT A3M1, Moates QH v1.6 BE, EA
Postby Diabolic » Thu Feb 04, 2010 8:27 am
Yes, they are selected on my payload. I've created a couple test payloads as well and the same occours. I go into levels and hit unselect all and then reselect all on both pages. Than save agin, and still get a "0" reading for both ACT and ECT. Stumped :cry:
Diabolic
Postby cgrey8 » Thu Feb 04, 2010 8:40 am
The only thing I can think of is make sure you are actually downloading/writing the tune each time you make payload changes. For the QH, a majority of the payload items have nothing to do with the tune, but for a select few like MAF, RPM, ACT, ECT, TPS, and a few others, the values must be acquired by having the EEC actively relay those values to the QH, and that required modification of the tune, which BE does for you in the background. But for those modifications to get into the QH, you must write the tune.
89 Ranger Supercab w/97 Explorer 302, Explorer (GT40p) headers, C&L 73mm MAF, TREPerformance 255lph fuel pump, aftermarket T5, 8.8" rear w/3.27s, Powertrax Locker, A9P & Moates Quarterhorse
Postby Diabolic » Thu Feb 04, 2010 11:06 am
I'm certain I'm doing this right. I'm doing the same thing I have been doing all along, and it was working perfectly. It just stopped working all of a sudden in the middle of a datalog and hasn't worked since.
Diabolic
Return to Tuning the EEC....
