It is currently Tue May 21, 2013 1:30 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Wed Mar 28, 2012 8:28 pm
Offline
have been looking for a table for the a/f in the cbaza eec.something like the a9 eecs,for open loop at different loads/You dial in the maf to the table then use the table to change the a/f to the desired?thanks Stan
Top
 Profile
PostPosted: Wed Mar 28, 2012 8:39 pm
Offline
Amateur Tooner
its called the stabilized fuel table fn1360
_________________
Top
 Profile
PostPosted: Thu May 17, 2012 6:29 am
Offline
Decipha, that table is all zero's in my def. What gives?
Thx,
Mike
_________________
95 Cobra- CBAZA/T4MO, TFS 170's, RPM 2, AFM N-71, QH/LC1, FMS 42lb inj, 90mm LMAF, MAC 1 3/4 longtubes, X, race bullets, 4:30's with a coilover/tubular front end, Baseline rear suspension, Draglite big/skinny's! 150 shot of gas coming...
Perfect is the enemy of very good!
Top
 Profile
PostPosted: Sun May 20, 2012 3:16 pm
Offline
Amateur Tooner
well sumtin' aint right, your probably looking at the fn1361 table with is the startup enrichment, unless the stabilized ect values have been cranked up high and the stabilized fuel table is actually deleted i.e. 0s
or could possibly be a bad def file
_________________
Top
 Profile
PostPosted: Sun May 20, 2012 8:40 pm
Offline
Hmmmm.....
1360 AND 1361 AND 1362are all zero's....
Temp - Stabilised Min ECT = 90 deg F
Temp - Min ECT for Stable ECT Hysteresis = 20 deg F
I'm still on BE 2009. I think it may be BE, b/c when I pull up other tunes that "professionals" have done, there are no changes between mine and theirs.
Any ideas?
_________________
Top
 Profile
PostPosted: Sun May 20, 2012 9:38 pm
Offline
Amateur Tooner
bad def file, get the full cbaza def from sailorbob
_________________
Top
 Profile
PostPosted: Mon May 21, 2012 7:26 am
Offline
Dongle UPGRADE.......
I wonder what else this has done to my tune. I've used Wes's Rev 47A off Clint's site.
Could it be a 2009 issue?
_________________
Top
 Profile
PostPosted: Mon May 28, 2012 2:58 pm
Offline
Amateur Tooner
a dongle is not an upgrade
_________________
Top
 Profile
PostPosted: Mon May 28, 2012 5:37 pm
Offline
It would be for someone coming from BE2009!
I purchased 2010, sailorbob's def., and sent in the QH for the 1.6 upgrade.
Now I wait.
_________________
Top
 Profile
PostPosted: Tue May 29, 2012 11:16 am
Offline
I had the exact same problem, I swapped computers with a friend that also had BE09 but his install was newer and it fixed the issue.
Top
 Profile
Search for:
Jump to:
