It is currently Tue May 21, 2013 10:02 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Wed Apr 04, 2012 5:10 am
Offline
Need help with my startup when hot (operating temp). Car starts up fine when cold...just hit the key.. When hot I have to crack the throttle a bit and hold the rpm's about 900 until My AFR gage reads 14.6-15.2. Usually takes about 15 sec. Once there it will idle fine at about 800rpms. What are some of the parameters I could change to help fix this? I do have 60lb injectors. I did change the timer to "0" at 180-200 temp so it doesnt subtract from my commanded fuel at startup. It helped a bit, but are there other parameters? Also it's commanding about 12.8-13.1 when starting up when at operating temp.
Thanks.
_________________
95gt stock short block, Ported xploder GT40p heads and intake, F cam, ARP head studs, 70mmTB, On3 Turbo Kit 10psi, Moates tuned by me, AODE done up. Drag radials, 327 rear.
Top
 Profile
PostPosted: Wed Apr 04, 2012 12:37 pm
Offline
Amateur Tooner
I have no idea what timer u set to 0 but if she's lean kick up the startup ol table. If she's not getting air kick up the multiplier table
_________________
Top
 Profile
Search for:
Jump to:
