It is currently Sun May 19, 2013 12:02 pm
Post new topic Reply to topic  [ 3 posts ]
PostPosted: Wed Apr 24, 2013 5:58 pm
I am making progress with my surging idle, I did make the lolod fixes and it helped. Now if I leave it in gear coming to a stop and then depress the clutch at 1000 to 1200 rpm it will settle into idle at 850. If I just depress the clutch and put it in neutral at say 2500 the rpms drop like a rock to 400/500 rpm and then the surging starts.
Is there a scalar that would slow the rpm drop so it just smoothly decreases to 900 and then settles in at 850, my desired idle?
Factory Five Roadster, 302 B cam, Explorer intake, Thumper Perf heads, 70mm Accufab TB, 80mm MAF, 12" Cold air pipe w/ small bend, 42lb FRP inj, AL9 Tweecer R/T BE & EEC Analyzer Best ET 12.898 @108.4
YouTube Videos: http://www.youtube.com/user/joeembery#p/u
My Pics:
http://s207.photobucket.com/albums/b...cpZZ1QQtppZZ16
PostPosted: Thu Apr 25, 2013 7:30 am
Do you have a VSS sensor on your setup? If so you can increase the minimum RPM for speeds above XX MPH (you can set that speed too). That is a main function of the vss sensor IIRC.
PostPosted: Thu Apr 25, 2013 7:32 am
You want to increase the dashpot preposition function
Users browsing this forum: cgrey8 and 4 guests
