It is currently Thu May 23, 2013 8:48 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Sun Apr 29, 2012 9:19 am
Offline
Been thinking about getting an aluminum car jack. Any recommendations? Anything to stay away from? Like something with low profile as possible, I have a sears branded iron and it weighs a ton and doesn't fit under the car without first using my smaller jack.
Jeff
_________________
It's not me...
1992 5.0 LX - 363 Dart Block, AFR185, 39lb Injectors, 80mm PRO-M MAF, HTM Custom Cam, Edelbrock RPM2, GForce T5, 4.10, BBK 1 3/4, 3" VRS Catted X-Pipe, A9L, Tweecer RT, BE, EA, LM-1
Top
 Profile
PostPosted: Sun Apr 29, 2012 10:05 am
Offline
I haven't found an aluminum jack that is worth the money (or maybe I'm just too frugal). I have this jack:
http://www.harborfreight.com/automotive ... 68048.html
It was branded "Central Pneumatic" when I bought it, but it appears to be the same jack. It gets under my GT, which is lowered 1", pretty well. It is steel, but its easy enough to carry around.
_________________
'92 Mustang GT
A9P (AOD to TKO swap)
Top
 Profile
PostPosted: Mon Apr 30, 2012 5:34 pm
Offline
Amateur Tooner
we got an aluminum jack from the snap on or maybe mac guy at the machine shop, that thing is nice i wanna say its a snap on?? but it sure does make life easy, i wana say itsblike $160 though so its kinda steep, definitely worthwhile if u intend on using it frequently
_________________
Top
 Profile
PostPosted: Tue May 01, 2012 9:58 am
Offline
stay away from the jegs ones. they're junk. I've had 2 now, sent one back for repair/replace, and the replacement failed after 6 months. used for race car.
_________________
1978 Mustang II King Cobra
5 spd Manual
Top
 Profile
Search for:
Jump to:
