It is currently Sun May 19, 2013 10:41 am
Post new topic Reply to topic  [ 2 posts ]
330ci or 347
330 33%  33%  [ 4 ]
330 33%  33%  [ 4 ]
347 17%  17%  [ 2 ]
347 17%  17%  [ 2 ]
Total votes : 12
Author Message
PostPosted: Tue Jul 06, 2004 6:27 am
Offline
just wondering if you guy's could give me some good info on which is a better choice and why?
_________________
302w
windsor snr lites
xe282hr comp cam
30lb, 70 maf, 75mm tb,adj fuel press reg
tfsr manifold
a9l, 1ddc
Top
 Profile
 Post subject:
PostPosted: Wed Jul 07, 2004 1:15 pm
Offline
The conventional wisdom is that the rod ratios of the 347 (or larger) strokers cause piston skirt and cylinder bore scuffing, so the 347s don't last as long as a shorter stroke engine. Also, the 347s tend to have the piston pin hole poking through the oil ring lands, so they don't seal as well either.
The 351W has more room for stroking, but it is taller and weighs a bunch more.
_________________
'89 LX 5.0, Crane 2040, Pro-M 80 mm, 65 mm TB, ported stock intake & E7TE heads, 24 lb injs., JBA shortys, cat X-pipe, A3M1 (GUFB strategy) w/Moates Quarterhorse, BE & EA, close ratio T5Z, 3.55 rear
Top
 Profile
Search for:
Jump to:
