It is currently Tue Jun 18, 2013 5:38 pm
Post new topic Reply to topic  [ 17 posts ]
PostPosted: Mon Sep 13, 2004 11:31 am
I still haven't been able to figure this part out. I want to know how to do this properly. I hooked up my wideband but what the data log says and what the display on the wideband says it's a different number. How do you adjust the AFR across the board?
Sorry guys for all the questions. The car is running right now thanks to Darren's help. I want to learn the process.
94 GT with
331 DSS stroker, J4J1, Vortech S-trim AFM power pipe digital 6 Aeromotive AFP,AFR 185 heads, 1.6 RR E303 Cam, jba headers,BBK 75mm TB, Pro-m 80mm . 42lb injectos, 255lph walbro intank pump, 255lph inline pump. 3.55 gears with viper T-56
 Post subject:
PostPosted: Mon Sep 13, 2004 11:42 am
My main question would be how do I know if the information from my wideband is accurate when it's data logging.
94 GT with
PostPosted: Mon Sep 13, 2004 2:56 pm
If this is true then the EEC Analyzer will calculate skewed data. Make sure to get the logged and displayed AFR on the WB to match before doing the calculations.
I believe there is a def file for each WB configuration. You may have to modify it to what you WB manufacture states it should be. I also remember reading somewhere that there is two different AFR curves for the AEM WB. One is for the unit that has the display and the other is for the non display unit.
Car Info
EEC Analyzer & Binary Editor
Other Photos
 Post subject:
PostPosted: Tue Sep 14, 2004 12:09 am
I will have to wait and ask Darren when he get's back from his business trip from Europe. He has the Plx M-300 as well and i'm pretty sure i'm just doing something wrong where I'm screwing something up that's simple.
94 GT with
 Post subject:
PostPosted: Tue Sep 14, 2004 12:11 am
86 are you in Dixon California? If so would you mind taking a look at my car and help me out. If in case you are in Cali
94 GT with
 Post subject:
PostPosted: Tue Sep 14, 2004 12:36 am
indeed, I am in dixon California. Fresno is a bit of a drive :lol: 2-3 hours. Let me know.
I know the WB uses the EGR input, but make sure you have EGR disconnect and nothing else is on the wire but the WB. Anything else on the line may cause the voltage to go down, which could cause bad readings.
Car Info
Other Photos
 Post subject:
PostPosted: Tue Sep 14, 2004 12:56 pm
I followed the wideband install instructions to the T let me know when you have time. I don't mind driving if you don't mind taking a look and helping me out.
Let me know if you are able to do so. and if so when would be a good time for that.
94 GT with
 Post subject:
PostPosted: Tue Sep 14, 2004 2:35 pm
Before any tuning with the WB can begin, the WB display and logged values need to match.
Do the voltages match, meaning if you convert the display back to a voltage, does it match the WB output to the EGR signal?
Car Info
Other Photos
 Post subject:
PostPosted: Wed Sep 15, 2004 12:43 pm
I don't think so How would I check to see? Thanks.
94 GT with
 Post subject:
PostPosted: Wed Sep 15, 2004 2:20 pm
Do you have the AFR curve from the manufacture? If so note what the AFR is on the WB at an idle, then cross reference it to the manufacture voltage chart, then compare that to what cal con is logging. If they do not match then the transfer that CalCon has needs to be modified.
Car Info
Other Photos
 Post subject:
PostPosted: Fri Sep 17, 2004 2:16 pm
It doesn't match is there a site that shows how to correct for it.
94 GT with
 Post subject:
PostPosted: Fri Sep 17, 2004 3:23 pm
If you have the transfer curve then I would open the *.DBF file in the data directory corresponding to your WB Manufacture in excel and modify the numbers. Then save it in the existing format and try it out.
Car Info
Other Photos
 Post subject:
PostPosted: Sat Sep 18, 2004 11:03 am
I will try this out today. thanks
94 GT with
 Post subject:
PostPosted: Sat Sep 18, 2004 2:02 pm
I have an LM-1 WB and when I modified the file I found that I had to change the name and then select the new file name in CalCon to get it to use the modified numbers. If I changed the file and left the name the same it would use the old values. This is with v1.0A7. Has anyone else seen this?
Deems Herring
1986 F150, 1992 5.0 GT 40 Aluminum head, B303 cam, A9L Mass air, Track Heat manifold, 70mm throttle body, BBK equal length shorty headers, Single 3" exhaust, Ford top loader 4 speed, 3.27 9" diff 24lb injectors C&L 73mm 24lb
 Post subject:
PostPosted: Sat Sep 18, 2004 5:49 pm
Yeah I got it to log correctly. 86 I sent you my latest log file
94 GT with
 Post subject:
PostPosted: Sat Sep 18, 2004 7:47 pm
Send me the CCF to go along with it.
Car Info
Other Photos
 Post subject:
PostPosted: Sat Sep 18, 2004 8:16 pm
I sent you the CCF back with a few changes.
Car Info
Other Photos
