I thought I would post some BE dashboards for all to try out and use if interested as a starting point. I will add more as time permits for me to build them. Once you have a dashboard installed you can customize it too your liking. Left click on a field to highlight it yellow, then hold left click and mouse drag will move the field. CTRL + left mouse button and drag mouse to resize. Double left click a field to open the gauge settings to set up. Download and save the dashboard to a file folder of your choosing or: C:\Program Files (x86)\BinaryEditor\Config\Dashboard\ whatever you want to name it goes hereAttachment:
DashboardEDS50-1.DSH [26.41 KiB]
Downloaded 400 times
DashboardEDS50-2.DSH [30.54 KiB]
Downloaded 273 times
_________________ 1989 GT - 25th Anniversary 5.0, Vortech S-Trim, TFS Trackheat Heads & Intake, TFS Stage 1 Cam, FRPP 1.6 RR, 75mm TB, Pro-M 80mm, Anderson Power Pipe, FRPP 42#s, GS-340/255 lph pump, Anderson 1-3/4 shorties, 3" Borla Exhaust, Tremec T-5, 3.73-31 spline, MSD 6AL2, complete-lowered suspension A9L, Moates QH/SL v1.6/1.4, BE, EA, Innovate LC-1/XD-16.
