It is currently Sat May 25, 2013 9:09 am
Post new topic Reply to topic  [ 202 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu Jun 28, 2012 9:58 am
decipha wrote:
it won't let me edit that post so...
heres a revised version with the math updated and a little more info
http://efidynotuning.com/idleair101.htm
Some good tips. In reading through this tho I noticed it instructs to remove the isc flow from the AM when building up fn875n, but i understood fn875n to correlate rpm to total AM. Why would you remove the isc flow for this function?
In looking closer, you use the total AM for the first entry to this function, but later advise removing isc flow when incrementing NUBASE up 500 rpm.
87 Mustang GT - R331, GUFB, 80-lb inj, PMAS maf, T78 turbo, AOD, 3,200 stall, E85/93, LC-1, TwEECer RT, BE2009/EA
89 Mustang GT -Explorer 302, CBAZA, TFS1 cam, 2005+ slot MAF, 4r70w, 2,800 stall, LC-1
PostPosted: Thu Jun 28, 2012 1:01 pm
i see what your saying now, i originally edited as i made the post and didnt erase that line, guess thats what happens when your in a hurry and dont proof read, ill fix it tonight
PostPosted: Sat Jun 30, 2012 2:59 am
vlydeka wrote:
We installed quarterhorse chip today in X3Z module with A9L2 cal, all I changed was injector size (high&low) and MAF transfer function. We definitely can feel the difference between X3Z cal and A9L2.
Only it's idling at about 1100RPM. We didn't drive it that much, does it have to learn? Or I need to change something in the bin file?
Please perform a Base Idle reset as outlined by Joel5.0-> LINK!!!
Certified; ASE Parts Pro(P2), Oracle Database Engineer
1990 Mustang LX Sport 'Vert, 5.0L, GT-40 Intake, SVO X303 Heads, Trick Flow Stage1 Cam, 24lb Inj, 70mm SVO MAF, 70mm Holley TB, BBK Ceramic L/T's & O/R H-pipe, T-5 'Z' Code, 31-Spline Trac-Loc(Carbon clutch packs), Moser 31-Spline Axles
GUFB - X3Z, Innovate MTX-L, Moates QH v1.6, TunerPro RT v5(Because I refuse to pay for tuning software that costs twice as much as my PC's OS)
PostPosted: Sat Jun 30, 2012 3:11 am
Oh duh, reason I came to this thread to begin with(rather than read through it). I have a question... Why is every Cell of the Injector Timing Table in your A9L2 set to 500? That's a bit late in the fill event.
PostPosted: Sat Jun 30, 2012 7:26 am
I don't want to speak for him, but I suspect it is done that way to work for any vehicle. Firing early wastes a decent amount of fuel on big cam engines. But firing late on mild engines, while isn't optimal, doesn't waste as much. For milder engines, feel free to readjust. The A9L2 is not meant to be a one-size-fits-all tune. It just gets closer than the stock tunes to fitting more applications.
There are some things in the tune that I don't necessarily agree with like the HEGO function adjustments, that appear to remove the HEGO table effectiveness and lock-in 1 behavior...presumably so people tinkering with the HEGO Bias/Amplitude, don't actually do anything. While I do have modifications to my HEGO functions, I didn't set them up with the explicit intent of disabling the ability to make quick RPM/Load changes in the HEGO tables. He had his reasons for doing this. If you don't like that, you have the power to change it to whatever you want.
The A9L2 is just another starting point for you to choose from when starting a new tune.
PostPosted: Sat Jun 30, 2012 10:30 am
500 isn't where it starts spraying, it where its done spraying
by spraying the injector as late as possible you keep your valves cleaner, we have a few racers that go through their engines every season and they all say the same thing, valves look great
but the main reason is as cgrey8 stated, if you have a cam with any overlap then you have to fire the injector as late as possible to get rid of the fuel smell at idle
PostPosted: Sat Jun 30, 2012 5:25 pm
DOH!! :surprised: I had totally forgot the Falling Edge switch. Man I have got to stop looking at Bin's when I'm half asleep. Thanks for replying guys.
PostPosted: Sat Jun 30, 2012 6:29 pm
decipha wrote:
increase the ithbma scalar
That worked, thank you for your help.
Now we will install 48# injectors, will try to dial in fuel and then will work on air.
I'm sure, I will have more questions shortly :biggrin:
PostPosted: Sun Jul 22, 2012 5:51 am
Decipha, wondering why there are different values (15,5,1) in the Adaptive Update table? Thought they should all be 3 or 5?? Thanks in advance...
1987 LX 5.0 Automatic Vert; Vortech S-trim, TFS Stage 1 cam, GT40P heads, TFS valve springs, Cobra Intake, Pro-M MAF, 70mm TB, V255 lph fuel pump, 30# injectors, 1.6 RR, shorty headers, no cat H-pipe, 2.5" exhaust.
A9P with modified A9T/C3W1 bin, Quarterhorse with BE/EA, Zeitronix zt-2 WB
PostPosted: Sun Jul 22, 2012 9:43 am
Probably has them higher at low rpms and low loads. Should help dial in fuel a little quicker. Higher the numbers higher the update rate is.
PostPosted: Sun Jul 22, 2012 1:47 pm
a higher number reduces the update rate, that number signifies how many switches is required at that range in order to update the kams
at idle you want accurate kams, in order to do so it can't update as often as it can at upper loads where the engine is much more stable
PostPosted: Sun Jul 22, 2012 11:26 pm
Ok, makes sense, but will the 1' at High Load/RPM affect WOT trims?
PostPosted: Mon Jul 23, 2012 7:17 am
it allows correction sooner
PostPosted: Thu Jul 26, 2012 1:22 pm
decipha wrote:
adjust your fuel how you would elsewise
if you read the air 101 youll understand ithbma tb airflow has no relation to tb size
ITHBMA is the amount of air the ecu can not control!!!
the other binaries arent properly patched
We had the engine running fine with 24# injectors, but now we are installing 48# injectors and we will need to dial in fuel. Could you please give me an understanding where should we start and what values to work with?
We installed wide band o2 sensor that we can record data to the computer.
To be able to start I changed injectors slopes and offset vs voltage.
PostPosted: Thu Jul 26, 2012 1:53 pm
Deleted
Factory Five Roadster, 302 B cam, Explorer intake, Thumper Perf heads, 70mm Accufab TB, 80mm MAF, 12" Cold air pipe w/ small bend, 42lb FRP inj, AL9 Tweecer R/T BE & EEC Analyzer Best ET 12.898 @108.4
YouTube Videos: http://www.youtube.com/user/joeembery#p/u
My Pics:
http://s207.photobucket.com/albums/b...cpZZ1QQtppZZ16
PostPosted: Thu Jul 26, 2012 2:00 pm
JoeFFR5294 wrote:
Start it up run the car conservatively and data log in as much use of the RPM (Tp) and go through the gears as much as you can. Then run the log through EA and work with the MAF adjusting tools in EA tweek the curve and repeat the datalog. After the second MAF tuning then try running in open loop datalogging and then back to the MAF tools.
We did not change MAF meter and kept 70mm throttle body, do we still need to adjust MAF or we need to dial in fuel?
PostPosted: Thu Jul 26, 2012 2:33 pm
I would work with the MAF unless you are already running at 14.5 to 15.5 AFR through moderate acceleration.
Deleted above posts
My bad missed the info on still using same MAF
My Pics:
PostPosted: Thu Jul 26, 2012 4:26 pm
You only changed fuel and not air. Why would you mess with MAF???
PostPosted: Fri Jul 27, 2012 7:04 pm
werd, im with homie ^
however, the stock fox body ecu's don't exactly have the maf curve dialed in there is some fluctuations, i think its more so the old ass electronics
but like folk said, keep the maf stock since your using a stock maf and dial in the injectors
PostPosted: Fri Jul 27, 2012 10:56 pm
This is what I'm thinking, since we swapped only injectors. Right now I have only injector slopes and offset vs V changed.
Is there Fuel calibration 101, like the direction for air that you put together? :)
Should I dial in fuel by using base fuel table (changing AFR)? What are my targets. I'm thinking to run different engine speeds and try to get different loads to record AFR with my innovate setup, then adjust fuel to where it's need to be. So I want to know what variables to change and what is ideal as a result?
PostPosted: Sat Jul 28, 2012 4:03 pm
load and rpm doesnt mean shit when dialing in fuel only lambse kamrf and mafv
air is air fuel is fuel, for x amount of air you need x amount of fuel to get x afr
in other words for mafv amount of air you need kamrf amount of fuel to get lambse afr
kamrf can be learned correction in closed loop or wideband in open loop same principle
PostPosted: Sat Jul 28, 2012 9:19 pm
So for now what I need to do is to drive the car and let it learn, that what you guys call dial in fuel? Then do idle air 101?
Sorry for so many questions, I'm new at this. I work with diesel engine calibration, and most of our maps are based on engine speed and load.
PostPosted: Sat Jul 28, 2012 9:43 pm
dialing in fuel is when your wideband matches your lambse, heres the link to tuning step 1
viewtopic.php?t=18470
that can also be entitled "fuel 101" 'cause thats what your doing
but yes you got the right idea, the great thing about what i did with the a9l2 cal is allow closed loop to dial in your WOT fuel when cold, this makes it much easier to get it where it needs to be
with mass air you have a mass airflow transfer function instead of having a VE map like you would with speed density
IMO mass air is more accurate and takes less time to dial in, it also compensates for changes better
in fuel 101 all your fueling questions will be answered if not don't hesitate to post there
cmlomax wrote:
First I want to say "Thanks" for posting your revised A9L2 calibration. I just changed it for my 24lb injectors and it worked wonders on my Mustang. I do have a question regarding what you changed however. I was wondering what changed that makes the EEC "hold" the RPM's during shifting? I noticed the revs seem to fall faster with this tune vs. stock and I'd like to change it back. If you could point me in the right direction as to what value needs to change, I would greatly appreciate it.
Carson
i do what i can
dashpot is the art of reducing rpms slowly as to prevent engine stall and also aid in emissions or so claimed
you can increase dashpot but adding more air in the dashpot pre-position function, this is assuming you have your idle air dialed in
idle air 101 http://www.efidynotuning.com/ford/idleair101.htm
PostPosted: Sat Jul 28, 2012 10:25 pm
but yes you got the right idea, the great thing about what i did with the a9l2 cal is allow closed loop to dial in your WOT fuel when cold.....
This is great info, that is exactly what I was looking for.... after driving for 20 miles today it doesn't look like fuel needs to be adjusted (just by looking at AFR gauge). Next step is to record AFR data then adjust injector slope. If I understand correctly, if I see WBO2 AFR rich compare to desired A9l2, I need to increase injectors slope, to reduce pulswidth and deliver less fuel.... correct?
Thank you,
Vaidas
PostPosted: Sun Jul 29, 2012 1:09 am
the afr gauge is useless without knowing what the lambse is
if the afr gauge did what you expected then that means closed loop has brought your fueling where it needs to be, you can now use the learned kamrf correction data to get your fuel where it needs to be
open up your tune and go to your maf transfer function, write down all the voltage values, now open your datalog and organize your datalog by mafv, then write down the average kam at each one of your maf voltages
the ONLY time you can adjust the slopes to bring your fueling closer is if it needs it at all points, if only a few points need adjustment then that can only be done in the maf curve
correct... a larger injector (higher slope) sprays less time (lower pw) for the same amount of fuel as a smaller injector
i was going to type something else but its eluding me at the present
PostPosted: Sun Jul 29, 2012 1:12 am
oh yeah i remember now
kamrf... that value is in percentage, 1.00=100% of calculated fuel was used, a value higher than 1 lets say 1.08 = 108%, which means it was lean and the ecu used 108% of the fuel it calculated, if the kamrf is below 1, perhaps .92=92%, then it was rich and the ecu used 92% of the fuel calculated
PostPosted: Sun Jul 29, 2012 9:03 am
Now I understand little bit better...still couple questions:
kamrf - MAF backflow correction table? And after driving values will change from 1 to lower or higher number
kam - is air flow value (kg/h)? Do I need to use this value in my new MAF TF or do I need to multiply/divide this value by the number from kamrf?
PostPosted: Sun Jul 29, 2012 9:10 am
Why on earth would anyone want to have clossed loop learning allowed during WOT conditions? This makes absolutely no sense to me :confused:
PostPosted: Sun Jul 29, 2012 12:09 pm
maf backflow table should all be 1s
kamrf is the learned correction stored in RAM, its only accessible by datalogging
kam is keep alive memory
when you log be sure the kamrf payloads are selected along with mafv and lambse
once you have a good log made you open the log with EA or excel, then arrange the
datalog by mafv, write down the average kam correction at each of the mafv
if you are applying that correction to the maf transfer then you multiply by the correction
value, example: 1.08 kam you simply multiply the flow by 1.08, if the kam is .92 at a specific
point then you multiply the flow by .92
Ed...
1> why not let the narrowbands dial the fuel in for you? that just less work you have to do
2> it verifies the wideband is accurate
3> much faster to dial in
4> a cold engine is not going to be hurt by running wot at stoich
5> those without a wideband know exactly where there wot fuel is at
PostPosted: Sun Jul 29, 2012 1:22 pm
decipha wrote:
Ed...
I am not quite sure anyone would run their car WOT cold or at least under 160 degrees. Just doesnt make sense. If you were to do this with a supercharged or turbo car you would have a mess on your hands no matter what temp. I dont understand why anyone would want adaptives to be in control of fueling during wot mode. Allowing adaptives to learn and closed loop operation during WOT is a strict no no to me and there is a reason why Ford engineers didnt enable it either. Its unsafe. Adaptives and closed loop operation are fine under 3.0 volts but anything above I dont want the hegos controlling my fuel to be stoich. I still stand firm that a wideband will always under any condition be more accurate than a narrow band any day of the week. If this works fine for you than great. I for one would not do things that way. To each his own.
