CBAZA base tune
Post by decipha » Sat Aug 11, 2012 4:52 pm
just like the A9L2 base tune for the foxbody ecu's heres a base tune for folks to get started on the CBAZA ecu's
IT IS IMPORTANT THAT YOU DO NOT LOAD ANY TEMPLATES OTHER THAN INJECTOR AND MAF VALUES, you could inadvertently negate a change and have some odd behavior, specifically the long tube header template and what not, its not needed
http://info.efidynotuning.com/t4m2.htm
the download also includes the U4P2 for ecu controlled automatic transmissions
just like the A9L2 this is good for basically anything from stock to turbo nitrous
//enjoy
FinnCobra
Re: CBAZA base tune
Post by FinnCobra » Sun Aug 12, 2012 10:55 am
Thank you ! 8)
I'll see how this is made.
Tommy1005
Re: CBAZA base tune
Post by Tommy1005 » Mon Aug 13, 2012 4:24 pm
wish I could use it, but supposedly sailorbob's strategy won't work on BE2012.....really could use a little head start. I atleast have the car idling now.
Re: CBAZA base tune
Post by decipha » Tue Aug 14, 2012 12:43 pm
simple enough just ditch 2012 and get 2010 contact clint
pfirmin1
Re: CBAZA base tune
Post by pfirmin1 » Tue Aug 14, 2012 2:54 pm
I was comparing this to the tune I have been playing with. I noticed you have changed quite a bit. Which calibration is it based on? Say I were to run this on mine, what would you suggest changing besides? Combo is 342 stroker, 190 trickflow fac heads, track head intake, 70mm throttle body and elbow, 80mm maf, 5 speed, no emissions.
Currently I have the high and low slopes set, injector breakpoint, battery offsets entered. Along with CI, trans type, egr and thermactor turned off. I havnt really played with fuel or timing yet, as I am trying to learn more. It does run good, but I know it has alot more in it.
Re: CBAZA base tune
Post by decipha » Tue Aug 14, 2012 4:56 pm
its based on my own calibration :)
just throw your sarchg, injector values and maf values in and set the transmission type and transmission control strategy scalars to disabled (standard transmission)
enjoy
pfirmin1
Re: CBAZA base tune
Post by pfirmin1 » Tue Aug 14, 2012 7:06 pm
Can you further explain sarchg? I have pops Cbaza strategy. Could it be listed as something else? Sometimes it gets confusing reading here versus whats listed in the definition file.
Re: CBAZA base tune
Post by decipha » Tue Aug 14, 2012 8:30 pm
sarchg is an abbreviation of standard aircharge it may be labeled as engine displacement
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 12:00 am
Would it work equally as well on a Kenne Bell setup? I've been tinkering with mine for months. Every time I think I have it at a spot where it's driveable and I can move on to the next issue, the original issue pops back up.... Would at least be good to compare it to.
95 Mustang GT - Quarter horse, Binary Editor 2012, T4M0, Kenne Bell 1.5L w/ Flowzilla @10 psi, 306, LMAF 90, 42# injectors, Gt40 heads, Gt40 lower, forged internals, dual widebands
Re: CBAZA base tune
Post by decipha » Sun Aug 19, 2012 1:07 pm
decipha wrote:just like the A9L2 this is good for basically anything from stock to turbo nitrous
pretty sure a little blower would fall between those 2
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 6:47 pm
Yeah, just figured I'd ask instead of assume. My IAT sensor has been relocated to the number 5 runner, I'll have to account for that in the tune, correct? My base was done by Lasota Racing so I didn't have to mess with any of those settings initially.
Re: CBAZA base tune
Post by decipha » Sun Aug 19, 2012 6:55 pm
maybe maybe not just depends, the act spark multiplier function controls the timing retard for act
its multiplied by .1 in the act multiplier table (10x) so just knock the decimal over one position and you've got your retard
-30 is 3 degrees retard, -60 is 6 degrees retard, etc...
can you send me your lasota tune, i'd be interested in seeing how well he knows these ecu's
decipha at efidynotuning dot com
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 7:03 pm
Definitely. I'll send the original base he gave me and not my current work of art...
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 7:12 pm
Base tune sent. Let me know if you see something you don't agree with.
Re: CBAZA base tune
Post by decipha » Sun Aug 19, 2012 7:33 pm
im at a loss for words i honestly having nothing to say, i hope you didn't pay much for that 'tune'
you'll notice the cbaza base tune is a significant improvement
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 8:27 pm
Ha. No I was given that after I had ordered my tuning setup from him to try and get me at least pointed in the right direction. That bad huh? I never compared it to a stock tune. Car started at least, good enough to get me going to do dial in my MAF curve. I'm waiting for a dongle from Clint and then I'll be giving yours a try. I'm sure it will be an improvement.
Re: CBAZA base tune
Post by decipha » Sun Aug 19, 2012 9:17 pm
(outdated info)
zerochance
Re: CBAZA base tune
Post by zerochance » Sun Aug 19, 2012 9:58 pm
Yeah, Clint is shipping out the dongle for me next week so I can use the premium def. I've been tinkering with the basic def since I bought the setup earlier this year. It'll be nice to have a full featured one for a change.
Re: CBAZA base tune
Post by decipha » Sun Aug 19, 2012 10:14 pm
yeah theres a bunch more in the cry def, sailorbobs has a little more than popsracing and is 8x cheaper
Blakonblak94
Re: CBAZA base tune
Post by Blakonblak94 » Mon Aug 20, 2012 11:23 pm
Decipha should we adjust the Throttle Body Airflow scalar accordingly as well?
1994 mustang gt. T5 w/mgw shifter, Slot-style MAF, trickflow trackheat intake, twisted wedge heads, Custom grind cam (212/218 with 115 lsa) 30lb injectors, BBK LT, x-pipe, Magnaflow Catback. LC-1 w/DB gauge logged through EVP, QH tuned with BE, Cbaza SailorBob Def.
Re: CBAZA base tune
Post by decipha » Tue Aug 21, 2012 12:06 am
yeah tune it as you would otherwise, check out the idle air 101 for more idle info if need be
MikeB
Re: CBAZA base tune
Post by MikeB » Sat Sep 01, 2012 11:06 pm
Decipha.....How are our borderline spark tables this far off? I was trying to be aggressive.
My base tables are 55'd out.
The car does feel down on power, so maybe I've got too much timing????
10.2:1 306, TFS 170's
95 Cobra- CBAZA/T4MO, TFS 185, Victor EFI, AFM N-91, QH/LC1, FMS 42lb inj, 90mm LMAF, MAC 1 3/4 longtubes, X, race bullets, 4:30's with a coilover/tubular front end, Baseline rear suspension, Draglite big/skinny's! 150 shot of gas coming...
Perfect is the enemy of very good!
Re: CBAZA base tune
Post by decipha » Thu Sep 06, 2012 9:10 am
damn it, shitty internet just caused me to lose about a 35 minute post
in short this is a base tune for everything, its not custom spec'd for everybody calibration as that is basically impossible with the limited spark control the ford ecu gives you, if you want something that you just plug in and go then you'll have to wait for the d.e.c.
spark is referenced based off load look at the row scaling, a stock 94-95 5.0 can only reach 75 load which would give them 22 degrees with this map, which is on the edge of detonation with 87 octane (in the mid rpms at least)
with your setup, I... would add 17 degrees from 45 load and up, and 13 degrees below that
if you do that correctly at 3k+ rpm youll get 35 degrees at 120 load and at 35 load youll get 55 degrees
just because you see 10 degrees at the top of the map doesn't mean anything, no tune should ever be allowed to get up there, only reason i do that is incase the reference line blows off the waste gate (had it happen) every little bit of safety helps when the 4 bar map sensor pegs out, could mean the difference between replacing head gaskets or replacing blocks
enjoy
Re: CBAZA base tune
Post by cgrey8 » Thu Sep 06, 2012 9:11 am
Do you use IE? I got tired of IE loosing my posts too. Firefox allows you to hit the back key and get what you typed back. IE doesn't. It got so bad for a while that I was literally copy/pasting all long responses into a text editor just so I still had my text in case the Internet took a dump all over my response.
Re: CBAZA base tune
Post by decipha » Thu Sep 06, 2012 9:13 am
yeah IE, its not bills fault though, im at work tethered through my android
Re: CBAZA base tune
Post by decipha » Thu Sep 06, 2012 9:20 am
oh yeah also, instead of pasting the word, you can press the print screen button possibly "PrtSC" in the proximity of the backspace key, then go to pbrush and paste it, save the pic and post that, makes it much easier
MikeB
Re: CBAZA base tune
Post by MikeB » Thu Sep 06, 2012 2:00 pm
I totally spaced on looking at the load. My load scaling only goes to 90, and at WOT, I see loads in the 90's. Should I rescale my load? Nitrous is in my future.
I'll play around with your timing recommendations.
Re: CBAZA base tune
Post by decipha » Fri Sep 07, 2012 9:09 am
if your only getting up to 90 load then be sure everything at 120 load and up is no more than 34
MikeB
Re: CBAZA base tune
Post by MikeB » Fri Sep 07, 2012 9:23 am
90's load N/A WOT
Will be higher with N2O.
Do I need to rescale load?
Re: CBAZA base tune
Post by decipha » Fri Sep 07, 2012 1:52 pm
you should be ok for now, just be sure 120+ isn't over 34, you still gotta tune it though
Users browsing this forum: No registered users and 142 guests
