Jack Hidley
CalCon 1.0A5 datalog file i/o prob - logs path can't be long
Post by Jack Hidley » Tue Mar 30, 2004 2:04 am
Previous versions of CalCon have used a DBASE file type with a dbf extension. CalCon now uses a Paradox file type with a db extension. When I open the dbf files in CalCon, they load correctly. When I try to load the db files, they don't load and I get the following message:
File name is too long for a Paradox version 5.0 table.
File F:\Documents and settings\Jack Hidley\My spreadsheets\Car\Engine\log files\040314143114.DB.
I've tried changing the filename to be 8.3 compliant by shortening it, but that didn't help. Any ideas?
I'm using version 1.0A5 of CalCon, version 1.30A8 of CalEdit on an A9L.
Jack Hidley
shonut
Re: CalCon 1.0A5 datalog file i/o problem
Post by shonut » Tue Mar 30, 2004 8:48 am
Jack Hidley wrote:Previous versions of CalCon have used a DBASE file type with a dbf extension. CalCon now uses a Paradox file type with a db extension. When I open the dbf files in CalCon, they load correctly. When I try to load the db files, they don't load and I get the following message:
What version was the log recorded with?
Has BDE been loaded?
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
www.shonutperformance.com
sales@shonutperformance.com
EEC Analyzer User - now with one-step WB-based MAF tuning
http://EECAnalyzer.webhop.net
Jack Hidley
Post by Jack Hidley » Tue Mar 30, 2004 12:13 pm
Josh,
Yes, BDE was loaded when I installed version 1.2 of CalEdit. I just looked in BDE administrator and I don't see any reference to Paradox .DB file types. The logs were all made in CalEdit 1.30A7.
Jack Hidley
shonut
Post by shonut » Wed Mar 31, 2004 12:08 am
Jack Hidley wrote:Josh,
Please e-mail me one. I've never seen this before.
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
shonut
Post by shonut » Wed Mar 31, 2004 8:07 am
Got them, they play fine, I've e-mailed you .csv's of the log that I created with CalCon 1.0V5.
I'd try uninstalling as much as you can (leave 1.20 if you have to) and re-installing.
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
Jack Hidley
Post by Jack Hidley » Thu Apr 01, 2004 12:36 am
Josh,
I tried uninstalling all of the STKR software plus BDE. I then reinstalled BDE, then 1.30A7, then 1.30A8. I still get the same error.
One other piece of information. I tried opening one of these Paradox datalog files with EEC Analyzer and got this error:
Error 09:DBase IV Connection Error
The connection was not valid. The Dbase file name 'EEC_Analyzer.mdb' can not contain number or underscores. Please rename the file and try again.
This sounds like there is some problem with BDE going on.
Jack Hidley
Jack Hidley
Post by Jack Hidley » Thu Apr 01, 2004 1:23 am
Josh,
I just spoke with Clint Garrity. He knew what the problem was. Apparently the complete length of the filename, including the path, can't exceed 65 characters with the Paradox files. I moved my log files to the root of the drive and they open correctly with both pieces of software.
This should probably be tagged and moved to the resolved issues section.
Jack Hidley
shonut
Post by shonut » Thu Apr 01, 2004 9:27 am
Clint mentiond that to me with reference to his own software, and now it all make sense. :)
Thanks!
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
