v8powerv8jim
94 Mustang turbo non starter
Well I'm having a very annoying issue with my 94 347 turbo,recently upgraded to a precision turbo and now it won't run.
It is tuned with a Tweecer,and it will fire up for 1-2seconds then die...but strangely if I switch the Tweecer off,it will start and run off the stock ECU but obviously crappy.
Things I have tried-
Swapping out the Tweecer for a known good unit,
Swapping the ECU and CCRM for another with the same fault.
Any ideas anyone?? Any help appreciated.
1994 GT,342 Sportsman B50,Vic JR Heads,HP Performance 76mm turbokit 16lbs,Trick Flow Box R series intake,MSD Pro Billet,AFM B41 Cam,1 7/8 headers,60lb inj,Vortech rails & Maxflow fuel kit,single 3.5" exhaust
Tweecer RT BE/EA CBAZA
Drivetrain-AOD with Lentech VB,UCC converter,4R70W internals,3.55's.
v8powerv8jim
Re: 94 Mustang turbo non starter
Ran codes,same old codes for deleted stuff only.
Code reader won't work with Tweecer in though,just keeps cycling fuel pumps on and off.
v8powerv8jim
12volts at injectors verified....still the same,fires up then immediately dies.
Switch Tweecer switch to off position,fires up and runs,but not good.
obviously your tune is corrupt or not configured correctly
v8powerv8jim
Yeah it looks that way but no changes have been made in the tune recently,I've tried loading the tune to all positions,and also wrote an older tune to it that I know is good.
v8powerv8jim
How does this tune look?
its a scaled tune,one 02,60 LB injectors....please take a look.
the whole back half of the tune is deleted
i copied it over from the t4m2
give it a check over and make sure nothing important changed
v8powerv8jim
Very weird....when you say the back half,which area of the tune? I'll take a look once I've access to my laptop soon
somewhere around 0xf000 on up
looks like a tune was written to a chip then copied out
Users browsing this forum: Google [Bot] and 38 guests
