2002stangGT
base TwEECer setup on 02 GT Automatic
Post by 2002stangGT » Sat Jun 21, 2003 1:24 pm
Where do I get the OEM binaries for a 2002 Mustang GT automatic? None of the files on TwEECer's site appear to work and my search here, Mustang message boards, TwEECer's Yahoo group, and a basic internet search was no help.
I get a successful "EEC Read Complete" message but the Scalar tab shows jacked up numbers (over 2000 ci instead of 281 ci, for example) no matter which built-in binary I choose. My EEC has MSH2 stamped on the sticker and CalEdit sees the EEC Strategy as GUFB. Board Rev. 5205B00E.
Any help? BTW, I'm new at this, so be gentle. ;)
Thanks!
action911
Post by action911 » Wed Jul 02, 2003 1:37 pm
I am also new at this.... I was told the best way to start with the TwEECer was to have somone burn you a chip, and then to have it put into the TwEECer so that you can use it as a base line to start with.
HJ :?:
Winston
Re: base TwEECer setup on 02 GT Automatic
Post by Winston » Thu Jul 03, 2003 6:40 am
2002stangGT wrote:Where do I get the OEM binaries for a 2002 Mustang GT automatic? None of the files on TwEECer's site appear to work and my search here, Mustang message boards, TwEECer's Yahoo group, and a basic internet search was no help.
Thanks!
The GUFB strategy is probably not for your processor ( A9L maybe ). You need a 4 banker and I think you should be using ryfao dat file and reading 4 banks. I have the ROM binaries for 02GT 5spd and may be close enough to get you going as probably only the transmission type is different.
2002stangGT
UPDATE. Still need help...
Post by 2002stangGT » Sat Jul 26, 2003 1:32 pm
Mike shot me info that weekend to use a 4-bank BIN file to start with. Here's what I did:
-I downloaded the LLX3.BIN.
-Under Input File I selected that BIN file, then changed the bank value to 4.
-I clicked "Read EEC" and let that process finish. It says it successfully reads the EEC.
-I clicked "Write TwEECer" and saved it as a CCF file.
-I then clicked "Read TwEECer" and selected the Scalar tab. Not knowing all the mumbo-jumbo yet, I bypassed reading most of the Scalar desc/values and searched the "engine_displacement" scalar, which looks correct (shows 280.74).
Without changing anything at all I tried starting the engine with the TwEECer plugged in (TwEECer in the "off" position) and it WILL NOT turn over. I tried it in the first position with the same results. As soon as I removed the TwEECer, it would start right up.
Totally frustrated that weekend, I let the install process sit until today. I took another shot today. SAME RESULTS. Another frustrating install attempt.
-Am I missing some steps in doing the initial install? Wrong file?
-Is it possibly a defective TwEECer chip?
Thanks!
-John
Winston
LLX3 comments
Post by Winston » Fri Aug 01, 2003 6:38 am
Not sure why you were told to load LLX3 binary as it is from a early 4.6L Cobra and is a 2 banker. When you load it it will bring up the CDAN4 strategy which is not the correct strategy for an O2GT auto or manual.
2002stangGT
Post by 2002stangGT » Sun Aug 10, 2003 5:33 pm
I was told to use the LLX3 file so I can have the option to select the number of banks.
Has anyone had luck installing on a 02GT austomatic? Anyone at all?
thanks!
-John
MilenniumGT
Post by MilenniumGT » Mon Aug 18, 2003 11:58 pm
N/M
Winston
02GT 5sp mde2 files
Post by Winston » Wed Aug 20, 2003 7:12 am
Try the file(s) that novicane has uploaded over at
http://tweecer.oplnk.net/viewtopic.php?t=866
They are for a 5spd 02 but they may be good enough to 'seed'
2002stangGT
Post by 2002stangGT » Mon Oct 13, 2003 8:42 pm
TTT.
Anyone? This TwEECer is collecting dust with no hope of working. One of the top TwEECer tuners here in Austin (and the only one I trust) said there are still issues working with the 2002 Mustangs with no resolution from STKR. He recommended that I go see Mike Murillo in SA since he uses Autologic. I was hoping to either install it myself or have it done locally but it looks like I'll have to take a trip...
Disappointing experience with STKR and this chip...
-John
Chuck Hoekstra
Post by Chuck Hoekstra » Wed Oct 15, 2003 10:55 am
Did you update you caledit.exe from Novicanes link? That cleared up all the problems for me.
A9P, TwEECer R/T, 306, AFR 165, Custom cam 109º LSA, Long tubes, Lightning 80mm MAF
