ashford
SD->MAF a few questions
Post by ashford » Tue Feb 17, 2015 10:18 am
im changing from lhblo to ahacb and have a few questions about the best way about doing things
1. the act, should i use the one in the maf or the manifold? the wiring is simple enought to change at this point, just wondering if the heat soak from the manifold mounted one would cause issues.
2. pcv vent. i have a 90mm accufab tb which has no provisions for pcv inlet, can the maf be programmed around unmetered air, i would like to keep the engine bay as clean as possible with minimum plumbing.
3. scaling airmass. when sd i went above the 63 lbs/hr limit in the ve table and had to scale it. will this apply to the maf ecu? i don't believe the engine to make more than 450hp and have a 90mm lightening maf.
62 falcon 4.6dohc czajl z4h0
85capri 2013 302, boss intake ms3
60 f100 427w e4od ahacb
83capri ms3 384w s475 e85 mid 9's
02 f350 7.3
Re: SD->MAF a few questions
Post by decipha » Tue Feb 17, 2015 2:36 pm
Maf
route to vac
90mm ford maf doesnt need to be scaled
ashford
Post by ashford » Wed Mar 04, 2015 7:59 am
got the conversion done, built a tune for it to match sensors ,rpm scaling etc. fired it up, shut it off and went home for the night, came back the next day and the tune was corrupted(replaced battery about a year ago). did a bit of minor tweaks i upped the air mass required in neutral and park and it was near perfect, burnt a chip and put it in for over the winter.
i don't believe how easy it was to get running well enough so that it was better than speed density, only 2 problems i had was the act in the maf is bad(!#%#$% ebay crap) and i will have to plumb a crankcase breather behind the maf
02 f350 7.3
Post by decipha » Wed Mar 04, 2015 1:07 pm
yep thats the beauty of mass air, you tune to the peripherals and not directly to the engine
Users browsing this forum: No registered users and 41 guests
