repairing a throttle body
Greetings ! How detrimental are vacuum leaks (smoke tested and made good smoke) at the throttle shaft , on a speed density system? I called the manufacturer and they wont sell me seals because of liability? Anyone know where to score seals to do this ? I think it has to be resealed top and bottom of the shaft. its a smokey mess. Thanks Bongo
93 Lightning 396w Frpp z heads ,frpp block, custom hydraulic roller .600 lift , ported gt40 lower with stock upper , level 10 E4od trans/converter, tweecer rt, speed density 42# injectors ,dual fuel tanks bbk throttle body, wideband,
Re: repairing a throttle body
On a MAF based system, they're a pretty big deal, but I don't think they matter that much on a speed-density system since the MAP should detect the vacuum change.
Users browsing this forum: No registered users and 34 guests
