I have just installed 60lb Siemens inj . this is a new motor but same spec's still 302 cuin.11lbs boost. anyway, at WOT in 3rd while tuning i am leaning out between 4900- 6000. I am sure i am out of fuel pump/system. it is all stock except a Walbro 255.
It appears that I only need a bit more, whats the simplest way to get enough to support 650-700. I am sure somebody has found this bandaid already. any suggestions are welcomed
need fuel pump advice
Re: need fuel pump advice
no worries your nowhere near 650-700
most likely your tune is to blame, go max out arcwotcor to 1.992 and she should be rich up top
Mike sorry I didn't see your reply earlier ,,,but that wasn't the case
