Eddieflores
What's the likely catch code for 95 Lightning EEC?
Hello, trying to find out what the catch /calibration code my eec has. Bought a 95 Lightning about 4 months ago and came with a fiveology maf kit and i would lile to know some info on this kit. Thinking of getting a tweecer to play with it a bit.
The eec has a charpie mark of 78-6167 on the gray part and some red numbers, 9445 2203 e9af 14a624 aa, gray part number foaf-14a459-aa and the sticker which I've seen before on original eecs is gone. Maf sensor part# f5uf-12b579aa 3j24.
Any and all help appreciated. Thanks.
95 ford, white lightning #0998 5.8, bd11a powerdyne, green top 42lb injectors, 90mm sct ba3000 maf, ngk tr5 plugs gapped to .35", bassani equal lenght headers, crane cams roller rockers, underdrive pulley, smog delete, fiveology maf kit, dual electric fans, dual flowmaster original 40's with side exits.
Re: What's the likely catch code for 95 Lightning EEC?
best bet is to get a qh and read the tune out, then youll know exactly what you have
Eddieflores
Will a tweecer rt work aswell? Thanks for ur help.
IIRC, the fiveology mass-air kits use the AHACB strategy.
Tweecer would work, but the QH is better.
Eddieflores
thanks guys for the info. reason why I ask if the tweecer rt will work is because i have been balancing my options around buying a tweecer rt or the qh and at this moment I've been offered a deal on a tweecer rt. so I was leaning towards it mpore, guess i'll try it and if I don't like it i'll save up again for the qh.thanks again guys , like the web site.
I would just do it right, and buy the QH the first time.
Eddieflores
Okay, after much thoughts, decided to buy the QH. And still more questions to come...will the aem wideband 30-4110 work with the qh? Or do i need to keep looking for another brand? Have ordered the binary editor and eec analyzer already, working on downloading the usb drivers. Any other things i might be forgetting? Thanks guys, really appreciate the help.
The wideband gets interfaced into the EGR valve position sensor input on the EEC. Nothing to do with the QH really.
e9af 14a624 aa
89 Taurus sho ecu?
what engine?
89 Taurus sho ecu?
what engine?
Users browsing this forum: Bing [Bot] and 26 guests
