ironmanisanemic
DIY Injector Flow Bench
Hello,
For the last few years i have been frustrated with most injector companies only giving static flow instead of full injector calibration data. Now i do know that for most, its workable. But if your like me, it is going to drive you up the wall when your trying to dial in the MAF and your injectors. Sometimes it felt like i was pissing into the wind trying to get things right. Looking for more information i found that Injector Dynamics outlines a pretty easy to follow article on Fords injector characterization. http://injectordynamics.com/articles/fo ... erization/ But alas, they dont appear to offer characterization services to the general public. Another good article i came across was from Greg Banish, https://calibratedsuccess.com/live-cour ... erization/ but again no dice in giving any indication on where it could be done. Finally i found a place that outright will do it, http://www.deatschwerks.com/support/ser ... r-services. But they are on the pricey side, costing $90 for the battery offset test, and another $90 for the "linearity" test. That was more than i spent on the injectors NEW! So i set off to design a low cost, user friendly, use what you got type of injector flow bench. Now, i know this is no easy task, but so far i have the bulk of the code written that will run on any Arduino uno or mini. It leverages the 16bit timer to control the frequency and the duty cycle, and uses an 8 bit timer to control how long to run the test. For now it uses a piece of software called MegunoLink Pro for the control interface. https://www.megunolink.com/ Unfortunetly, its not a free piece of software, but there is a trial version that i believe will work for just checking out what ive done. I plan on getting the ASE tech doc that discusses injector characterization in more detail, but i do know that most all testing is done at a simulated 6000RPM, and a pulse width from 0-10ms. This correlates to 0-100% duty cycle since 6000RPM equates to only a 100hz square wave. I plan to further expand upon the code to get away from the MegunoLink software, and move to a LCD screen with some form of menu and user interface, as well as add feedback for pump and fuel pressure control. Ive also started to rough out the hardware side of things and have made up a small PCB that currently only is controlling 1 injector, but can easily be scaled up, once the final circuit has been designed. I havent begun to draw up the enclosure, but in the grand scheme of things thats the easy part. I will attach a few pictures, screen shots as well as the source and dashboard for megunolink so others can give it a try. Im very open to suggestions, help with coding and circuitry as i am still very green in both aspects. If this becomes popular enough i could put this up on gethub, but for now posting it here will suffice.
EDIT
I forgot to add that i know there are a ton of DIY "Injector benches" on the internet. What i aim to do with this, is have a repeatable platform that can perform characterization of unknown injectors or decapped injectors. It can also serve as a cleaning station. What other solutions have failed to address is the repeatability factor. Most ive seen trolling youtube use a toggle switch and a stop watch to flow injectors.
I will try to make up a small video of my setup working and hopefully post it up tomorrow.
EDIT
1989 Ford Bronco:
1995 Ford Mustang GT
Re: DIY Injector Flow Bench
That's excellent work.
I do know Fuel Injector Connection has standard flow bench machines that can pulse the injectors at different PWs. The machine doesn't "simulate" RPMs. It's more interested in the length of the ON PW and the total time the test runs. I think most of the tests they run and value the results of are with a 50% duty cycle. However I believe the machine can do anything from 10-100%. The setup they show on youtube is the same setup I saw when I went to their facility (a shop in the back of the owner's home).
I still have, floating in the back of my head, hope of partnering up with someone to design an open source EEC replacement similar to what MegaSquirt uses, but based on modern stuff like Linux and Java. While there are real-time aspects that simply cannot be done in this environment, there are hardware solutions out there now that have ARM Cortex A-series and M-series processors on the same die that would work perfectly for this kind of project. The real time stuff could go in the Cortex M processor (running at ~200MHz) while the Cortex A could run Linux and a JVM at 1GHz including giving the hardware the ability to do WiFi (not Bluetooth), possibly run a web-based interface, and massively more programming flexibility & debugging ability than reverse-engineering 20-30 year old BINs.
ironmanisanemic
I say simulate RPM only because it's easier to understand by most to say RPM than some arbitrary frequency. I'll show it in more detail in a video, but the frequency and pulse width are all calculated and displayed on the control interface so you still have all of your information. Right now I can select any value from 1 RPM up to say 20000rpm (haven't actually calculated out the upper limit, ive tested it to 18000rpm) 0.01% dc - 100% dc, and 0.01 Second on time to 70ish days(it's the theoretical max value in the timer that's being used for the time on). I would like to add the ability to sweep the RPM and simulate dynamic driving like what the commercial units do. But right now I need to focus on getting a reliably working schematic for the electronics, and get a few boards made up to test.
1989 Ford Bronco:
ironmanisanemic
So last night I was able to record a shortish video on how things work. Hopefully it's easy to follow. https://youtu.be/lcwjgRoaD-Q
1989 Ford Bronco:
Excellent project , the testing seems for be excellent for a diy project even at this stage, i am glad you are sharing the source code , do you mind sharing a little bit of the raw schematics and p/n for the mosfet?? maybe i can help with a little parallel tests
89 LX : 351w AFR185,Trickflow R Intake,Lunati 51014,BBK Headers A9L2
97 Cobra : Stock Just Tweecer RT
ironmanisanemic
here is the part number for the FET PSMN022-30PL i just had a bunch of these laying around. They are far from ideal with a relatively high RDS on resistance, but are still a good MOSFET for the price per unit. I attached a basic schematic of how i have it wired currently.
The pull down resistor is a 15k
the 2 diodes arent completely necessary, but are there for reverse voltage protection. They can be any diode as long as the one on the ground side of the MOSFET can handle higher currents.
The rest should be fairly straight forward.
1989 Ford Bronco:
Excellent will start to build it this week, i will post as soon is built
CrashD1n3r
So what's up with the project? I've been looking for a project like this for long! I've built the setup and it's working but how would you go about measuring the low slope, high slope and BP?
Have you considered something like an IRLB3034? We use them in airsoft applications (DC brushed motor, imagine the electrical noise) due to their high current capacity and "low" RDSon. They also have a cast-in TVS circuit, though its small.
Also, I may adapt this to my Mega2560, if it has the timers necessary...
EDIT:
A quick search on Google suggests that the 2560 has 6 timers, 4 of which are 16bit.
EDIT:
ironmanisanemic
That fet looks pretty good. It should work pretty well in this application. I might pickup a few and give them a try.motorhead1991 wrote: ↑Wed Nov 29, 2017 10:48 pm Have you considered something like an IRLB3034? We use them in airsoft applications (DC brushed motor, imagine the electrical noise) due to their high current capacity and "low" RDSon. They also have a cast-in TVS circuit, though its small.
EDIT:
The code will drop right in to a 2560 without any modifications to the code, as the first 3(?) timers are the same between the uno and the mega.
I've taken a bit of a hiatus from most projects lately so I can spend more time with my family.
I thought about using a mega, but their aren't many advantages unless you try to implement all 4 timers and give each injector driver its own timer output, but for this it's not really necessary. It also has more program space, but that's not an issue at the moment since the current code base only uses about 25% of the memory of an uno. It still has plenty of room to grow.
I still plan to make up a prototype board with more thought taken in the design of the controls to make things more robust. Just need the time to get to it.
Also still need to design an enclosure for the bench. I have a friend that owes me some favors that will let me use his plasma table as much as i want, i just need to purchase the metal.
I would like to find some kind of electronically adjusted fpr, so pressure can be a closed loop feedback and adjusted on the fly. If anyone has any suggestions for something along those lines.
If there is anything that anyone would like to help with or features that you feel would be good to implement just let me know. Im only one person and have a full time job and a family, so if it's just me doing all of the work it might never get finished.
1989 Ford Bronco:
Bump. Any new updates on this?
ironmanisanemic
No, I haven't had much of a chance to work on the hardware. But i have been working on splitting the code to have a python front end that will send the parameters to the backend code that's in the arduino. That way it is cross platform and could be run from a raspberry pi for a compact all in one solution.
1989 Ford Bronco:
Loganhannah
I also tried to create a DIY Injector Flow Bench which is consisted of:
Its processing is simple after being assembled.
You need to take the cap off pour specially formulated injector cleaner in the pipe with the ball valve closed, and put the cap back on, then attach shop air to the nipple in the cap. Then set your regulator until the pressure on the fuel gauge reads your desired test pressure attach injector or test rail with injectors mounted open ball valve and hit the start button on the fuel injector tester. Measure how much fuel sprays into the graduated cylinder in 30 Seconds, then multiply that amount by 2 to get cc/min of flow.
For hand tools guide: https://handtoolsforfun.com/
- Injector pulse tool set to 90% duty cycle and 30 second intervals
3" galvanized Pipe 3 ft long
2 3" galvanized Caps
1/4 Angle Ball valve
Air hose adapter to attach a air compressor hose
Brass T with 1/8NPT fitting for Fuel pressure gauge
High Pressure Fuel injection hose
Large Ultrasonic Cleaner.
500ml/500cc graduated cylinder
Fuel Filter
