ECC IV Chip Case
kmplace
ECC IV Chip Case
Post by kmplace » Thu Dec 14, 2017 8:22 am
I have made this case to go on the End of the computer to protect my moates OH, would anyone have any interest in these? i could provide the STL file and you can take to local 3D print shop or i could possible make a few
Moates Lid.jpg (28.51 KiB) Viewed 1444 times
ecc case.JPG (121.96 KiB) Viewed 1445 times
1993 SSP Mustang, 302,GT40 Heads, Downs upper, LJMS Custom turbo cam, BW S366 turbo, A9L QH:BE
Re: ECC IV Chip Case
Post by motorhead1991 » Thu Dec 14, 2017 11:52 am
Might even fit the early EEC-Vs. I know my FLH2 (EEC-V) had a similar sized hole as my M0M2 (EEC-IV)
ironmanisanemic
Post by ironmanisanemic » Fri Dec 15, 2017 11:52 am
I'd be interested in the model. There are a few different case designs that I've seen for the ecus but the same piece should be able to be tweaked to fit them all.
1989 Ford Bronco:
-393W, Edelbrock Performer RPM heads, ProComp Upper and lower intake, Custom Comp Hyd Roller cam, 10:1 compression, 30lb injectors, 75mm TB, Pro-M 80mm MAF, equal length short tube headers, 2.5 inch y pipe merged into single 3 inch with hooker aerochamber muffler and no cat, QH w/ BE and EA running U4P0, AOD
1995 Ford Mustang GT
Tun3r
Post by Tun3r » Tue Apr 10, 2018 11:55 pm
you've done a great job on that one
