A previous owner cut the ODB-I test plug and wires.
I am planning on going to a wreaking yard and getting a plug to replace the missing one. My code scanner has an adapter plug to go from the ODB-II to ODB-I. So.... what is the problem with getting an ODB-II plug and wiring it to the EEC so I dont need the adapter plug for the scanner????
Also, any part numbers or size on the tool to remove the pin sockets on the wiring plug going to the EEC-IV. The wires were cut leaving about 1/4 inch of wire!!
- Cruisin428
EEC-IV ODB-1 missing re-wire with ODB-II plug
347 AFR 205cc Race Heads cam?? 90mm Ford MAF siemens deca 60lb injectors MSD Dist & 6AL Vortech V-3 Headers to side pipes- Stick shift
No A/C, EGR or Smog at all
Re: EEC-IV ODB-1 missing re-wire with ODB-II plug
New OBD2 plugs with virgin terminals don't cost that much ;)Cruisin428 wrote: ↑Mon Jul 23, 2018 12:15 am A previous owner cut the ODB-I test plug and wires.
