Tuner2019
binary editor hardware not found
Post by Tuner2019 » Sun Jun 23, 2019 9:50 am
The hardware is seen by TunerPRO but not binary editor. it is licensed. Havent used it yet.
To confirm it is not the chip or computer the fuel pump does constantly run with key on and The computer does make a notification noise as well as say it is using com5 for the USB. I tried com3 but no change in results.
Tuner2019
Re: binary editor hardware not found
Post by Tuner2019 » Mon Jun 24, 2019 4:21 pm
Got it reading now.
It was a driver issue. Uses a different driver than TunerPRO .
Post by motorhead1991 » Mon Jun 24, 2019 5:06 pm
I believe TPRT can use the BE driver but not vice-versa. I switch between the two all the time.
Users browsing this forum: Bing [Bot] and 30 guests
