glaser67
Possible VSS delete?
Post by glaser67 » Mon Aug 23, 2021 7:01 am
Ran into a problem with converting my 91' F150 from E4OD to M5OD; I get the tranny, T-case, and crossmember mounted up, and there's a conflict with the VSS/Speedo cable and the corner of the front fuel tank. I cannot lower the drivetrain enough to miss it, and to move/remove the tank I'd have to pull the bed.
What are the implications of deleting the VSS? I would anticipate decel idle issues and such, but am unaware of how might affect drivability or of there's a way to compensate with the tune.
Any insight would be greatly appreciated.
-Glaser67
89' F-150, NA 5.0, MAF conversion - Quarterhorse w/Binary Editor, A9L, GUFB
Re: Possible VSS delete?
Post by jsa » Mon Aug 23, 2021 8:59 am
Turn the VSS hardware present switch off in the tune.
glaser67
Post by glaser67 » Mon Aug 23, 2021 9:15 am
Will do, thanks for quick reply.
For my understanding, does this simply eliminate the function(s) that are affected by VSS input (decell, decell in/out of gear)?
Also triggers another question for the tuning community; E4OD has the shift position module which functions as a neutral safety switch, which I planned on putting in the park or neutral position and just tying up under the cab.
Does having constant neutral safety closed affect driving conditions?
I think the answer would close the loop on the manual conversion as far as electronics and the tune is concerned.
Post by jsa » Mon Aug 23, 2021 7:16 pm
Search the strategy doc for VSS, all the implications are covered.
https://github.com/OpenEEC-Project/Strategy-Documents
Search TRLOAD in the doc. Set it in your tune to suit your transmission configuration.
