sriner86
Godzilla coil packs with EECV
Post by sriner86 » Mon Nov 29, 2021 10:08 am
I recently noticed that the coil packs used on the new Ford 7.3L "Godzilla" engine are two wire and have nice mounting tabs. Do you think these could be used with an EEC-V for a sbf cnp conversion?
sriner86
Re: Godzilla coil packs with EECV
Post by sriner86 » Fri Jan 14, 2022 3:05 pm
In case anyone finds this later, myself along with the help from some other forums members have determined that these coils should work with the EECV. We plan to try them once everything is installed.
Some info:
P/N: Motorcraft DG587
Dwell: 1.95 ms
Connector: Ballenger CONN-76130, https://www.bmotorsports.com/shop/produ ... ts_id/4630
Plug Wires: ?? So far only know of factory 7.3L ones
