Jman
SFI-MA13 for use with GUFB
Post by Jman » Thu Oct 02, 2025 1:53 am
I've been wanting to try this for a while and will try out using TIP102 transistors for the missing injector drivers. I've harvested heat sinks, 36v 5watt Zeners, and 470ohm base resistors from an A9S so if there is any difference in the injector waveforms with the TIP102 transistors I'll know it's the transistors and not the other components. I think xd41efisc mentioned doing this but don't remember the outcome.
I ordered a Pico TA018 amp clamp for my scope to check the injector wave forms when I get this going and will try to post the wave forms here.
Thank you
J.W.S.
