I know this must sound stupid but i just got my TwEECer and have tried looking for the J3 port and can't find it....is it behind the insolationat the top of the computer?? This is my first mustang and i haven't had any custom chips or anything. Please any help would be great. BTW it's a 94 GT.
Peace Out
Drew
BlkGld94GT
J3 port???
1994 5.0 5spd,TwEECer R/T (CBAZA/J4J1), GT-40 Iron heads, Explorer Intake, Trickflow Stg1, K&N, FRPP 3.73:1, BBK O/R X-pipe, Catback w/ Flowtech Warlocks
Ryan McCormick
Ford Fuel Injection.com
It is under the gray cover at the opposite end of the computer from the 60 pin connector. I had to grind the case on mine in order for it to seat good, hopefully you won't have the same problem.
95 GT - T4M0
BB&T 331, AFR 165's, 1.6 RR's, Turbo Cam, Cobra Intake, 42#, 70mm TB, EGR delete, no smog, 3" Pro-M Univer, PT-70 Turbo kit with B&G headers and a custom y-pipe with 3" catco cat. Tweecing currently for 9-12psi with an RT, and PLX M-250.
BlkGld94GT
rockin_rick
IIRC, mine was a black plastic plug that just popped out. No grinding required. Lots of circuit board (the fingers of the edge connector) cleaning necessary, though...
Rick
Rick
Users browsing this forum: Google [Bot] and 28 guests
