jamie from oz
Re: Data offsetting in BE
ok that will take a bit to sink in .
(60 pin EEC-V 8065)
so if in your example code 0x84BC has been changed to [r14+d00] and QH is looking at that position to find the data ?
ok so if i have data that is referred to at 0xABFA in the register of [r0+d00] and i want the data to be in the QH payload in free space at 0xEE00 .
i put in Address column A2 = 0xABFA and can have the offset in E2 = 0000 or EE00 ???
i will read throuh it a couple more times and i hadnt looked in the GUFB work sheet that appears to have some instructions that might help the penny drop .
Jamie
(60 pin EEC-V 8065)
Jamie
jamie from oz
ok so i think i found where the code in gufb came from [0x84BB: 1c,c3,15,00,0d,1c]
0x84BB 0x1C
0x84BC 0xC3 st REG_1C,$0D00[REG_14]
0x84BD 0x15
0x84BE 0x00
0x84BF 0x0D
0x84C0 0x1C
so the data column has the string of code that is at that address .
the 0xEE00 goes at B62 for EEC_IV and B127 for EEC_V .
this is in my code
abfa: a3,01,00,0d,24 ldw R24,[R0+d00] R24 = [d00];
so i will have
0xABFA 0xa3
0xABFB 0x01
0xABFC 0x00
0xABFD 0x0d
0xABFE 0x24 .
0x84BB 0x1C
0x84BD 0x15
0x84BE 0x00
0x84BF 0x0D
0x84C0 0x1C
this is in my code
so i will have
0xABFA 0xa3
0xABFB 0x01
0xABFC 0x00
0xABFD 0x0d
0xABFE 0x24 .
jamie from oz
yes i think i follow after looking at it more
this is the whole sub route that i enter into the address column.
(you had previously mentioned that 1f1c was in the console sub route)
Sub_abfa: " engineering console present ???"
abff: 99,3b,25 cmpb R25,3b
ac02: d7,03 jne ac07 if (R25 = 3b) {
ac04: ef,f9,6b call 1800 1800 (); }
ac07: a3,01,f2,1f,38 ldw R38,[R0+1ff2] R38 = [1ff2];
ac0c: 89,1c,1f,38 cmpw R38,1f1c
ac10: d7,03 jne ac15 if (R38 = 1f1c) {
ac12: ef,07,73 call 1f1c 1f1c (); }
ac15: f0 ret return;
by puting this into the QH tab BE knows where it can put its reference to the patch
Attach a spreadsheet with just your QHorse tab here. Then I'll be able to give you better feedback.
jamie from oz
ok i have a screen shot .
8065 is the important information.jamie from oz wrote: ↑Tue Oct 25, 2022 6:02 am ok that will take a bit to sink in .
(60 pin EEC-V 8065)
R14 is getting the first address from the payload list at 0x84EE.so if in your example code 0x84BC has been changed to [r14+d00] and QH is looking at that position to find the data ?
Say you select GUFB ACT on the Payload tab for logging. BE will put the register address 0xB1 in the payload list starting at 0x84EE.
The code resolves [R14+D00] too [B1+D00]=DB1. The patchcode will copy ACT data from 0xB1 to 0xDB1. BE will read ACT data from 0xDB1 and put it in your log file.
Column B DATA has one byte of code in each cell. BE will write that byte of code to the adjacent address in Column A ADDRESS.jamie from oz wrote: ↑Tue Oct 25, 2022 6:38 am ok so i think i found where the code in gufb came fromso the data column has the string of code that is at that address .Code: Select all
[0x84BB: 1c,c3,15,00,0d,1c] 0x84BB 0x1C 0x84BC 0xC3 st REG_1C,$0D00[REG_14] 0x84BD 0x15 0x84BE 0x00 0x84BF 0x0D 0x84C0 0x1C
Cell B62 would be correct for a GUFB type patch code.the 0xEE00 goes at B62 for EEC_IV and B127 for EEC_V .
Cell B62 may well work out for your 6DBX, time will tell, more later.
Cell B127 for 8065, it depends on the patchcode space required.
The cell is not dependent on 8061 or 8065.
This note in Cell D62 is key
This is the marker to tell BE where to put the EEC-fetched payload list. The 1st instruction of the patch code above must reference this address.
You have changed the operation address mode. Best to leave it as it was.this is in my codeCode: Select all
1F1C yes, and D00 as well. more on it later.jamie from oz wrote: ↑Tue Oct 25, 2022 7:12 am (you had previously mentioned that 1f1c was in the console sub route)by puting this into the QH tab BE knows where it can put its reference to the patchCode: Select all
Sub_abfa: " engineering console present ???" abfa: a3,01,00,0d,24 ldw R24,[R0+d00] R24 = [d00]; abff: 99,3b,25 cmpb R25,3b ac02: d7,03 jne ac07 if (R25 = 3b) { ac04: ef,f9,6b call 1800 1800 (); } ac07: a3,01,f2,1f,38 ldw R38,[R0+1ff2] R38 = [1ff2]; ac0c: 89,1c,1f,38 cmpw R38,1f1c ac10: d7,03 jne ac15 if (R38 = 1f1c) { ac12: ef,07,73 call 1f1c 1f1c (); } ac15: f0 ret return;
Not much chop, can you paste column A & B to code chunk in a post then.
More background info in the next post.
More background information...
I have this in a 6DBX_CMT.txt file.
A couple things among many happen early on after the EEC boots up;
* The background vector list is loaded and executed
* The checksum of the binary is tested
The Vector List is of interest because the Console routine is typically the first vector and the first in the sub-loops as well.
Searching the disassembly _LST for D00 and 1F1C finds;
ABFA is the first address of that Sub.
Searching the disassembly _LST for ABFA finds a number of instances in the vector list;
Searching the disassembly _LST for the Vector List start address finds;
Confidence that the Console sub has been found is high.
What else gives reason to believe it...
Having read the EEC manuals you would be aware that D00, 1800, 1FF2 and 1F1C are not the sort of places you find code that normally operates from the ROM chip. The manuals will also allude to memory being reserved for consoles in those areas. So yes that is the console routine. It will be overwritten by patchcode by BE as layed out in the QHorse tab.
GUFB uses R14 as a scratch, all good for 8061, but that is a Special Function Register in 8065. We would wreak havoc if we used R14 as scratch on 8065.
Note R24 and R38 being used as scratch, we will use them in our patch. I see you (Jamie) have R24 already.
The console routine is 28 bytes long, we need to keep that in mind as a patchcode space impact...
GUFB patchcode is much longer than that...more later.
Checksum should be considered as well. BE is supposed to update the checksum when changes are sent to the ROM on the QH.
Checksum normally starts at address 0x2000 so lets search _LST for that;
We find some Words or a Structure starting at address A25E.
Searching _LST for A25E finds;
That code adds up words from 0x2000 to 0xFFF0, without carry.
It should ADD up to Zero.
If it adds up to anything else, fail and set code 511.
The patchcode will go to ABFA or NOT. Patchcode length forces us to put some or all patchcode elsewhere.
If patchcode replaced ABFA within the checksum address range. Your DEF would need the correct checksum addresses on the Config tab and BE to do it's part.
From _LST
The payload list can go anywhere in the fill from EDCA.
Some BINS will limit the upper range of the checksum to something like EDFE, giving the option of having the payload list inside or outside the checksum address range.
6DBX default does not give the option, so the payload list will be in the checksum range.
Config tab needs to be right and BE has to do it's part.
Jamie's selection of EE00 for the Payload List is ok, BUT space is required for the patchcode. So lets go with patchcode space and payload list from EE00 up.
EE00 is a ROM address, that is Read ONLY Memory with regard to the OEM ROM.
Is EE00 a good DatalogOffset choice for payload data to be Written too by the uP...
I have been assured that the QH is supposed to be smart enough to accept writes to read addresses...
I have had better luck using a RAM address for the DatalogOffset.
...so which RAM address...well the Console Sub uses D00 and 1Fxx.
I use D00 for DataloOffset with success for the BINS I've logged.
224D # Load the Background Vector List address
237B \n\n #### BACKGROUND VECTOR LIST
237C # Console Sub will be over written with patchcode
A23B # Load Checksum Structure address
A25A # Checksum Failed, set code 511
A25D \n\n #### CHECKSUM ADDRESS STRUCTURE
A25E # Checksum Start Address
A260 # Checksum End Address
ABFA # R24 is a scratch Reg
AC02 # Hi Byte of R24
AC06 \n\n # JNE from LAC02 no Console \t83\sABFA
AC07 # R38 is a scratch Reg
AC14 \n\n # JNE from LAC10 Console binary Sub1F1C not loaded \t83\sABFA
Sub A237 "SubA237_Checksum"
Sub ABFA "SbgABFA_CC_Patch"
237C: fa,ab vect abfa Sub_ABFA
23B2: fa,ab vect abfa Sub_ABFA
23D0: fa,ab vect abfa Sub_ABFA
23F4: fa,ab vect abfa Sub_ABFA
224d: 65,7c,23,38 ad2w R38,237c R38 += 237c; # Load the Background Vector List address
SbgABFA_CC_Patch:
abfa: a3,01,00,0d,24 ldw R24,[R0+d00] R24 = [d00]; # R24 is a scratch Reg
ac02: d7,03 jne ac07 if (R25 = 3b) { # Hi Byte of R24
# JNE from LAC02 no Console SbgABFA_CC_Patch
ac07: a3,01,f2,1f,38 ldw R38,[R0+1ff2] R38 = [1ff2]; # R38 is a scratch Reg
# JNE from LAC10 Console binary Sub1F1C not loaded SbgABFA_CC_Patch
a25e: 00,20 word 2000 # Checksum Start Address
a260: f0,ff word fff0 # Checksum End Address
a262: 00,00 word 0
SubA237_Checksum:
a237: 01,38 clrw R38 R38 = 0;
a239: 01,44 clrw R44 R44 = 0;
a23b: a1,5e,a2,4a ldw R4a,a25e R4a = a25e; # Load Checksum Structure address
a23f: 46,4b,00,42 ad3w R42,R0,[R4a++] R42 = [R4a++];
a243: df,0d je a252 if (R42 != 0) {
a245: a2,4b,46 ldw R46,[R4a++] R46 = [R4a++];
a248: 66,43,44 ad2w R44,[R42++] R44 += [R42++];
a24b: 88,46,42 cmpw R42,R46
a24e: d1,f8 jleu a248 if (R42 <= R46) goto a248;
a250: 27,ed sjmp a23f goto a23f; }
a252: 88,44,00 cmpw R0,R44
a255: df,05 je a25c if (R44 != 0) {
a257: ef,15,04 call a66f Sub_a66f (
a25a: 11,05 #arg 1 511 ); } # Checksum Failed, set code 511
a25c: 20,45 sjmp a2a3 goto a2a3;
From _LST
edca -> ffff = 0xff ## fill ##
jamie from oz
I think i follow that.
I didn't proceed past the end of the console route because t thought it will need to be different.
ADDRESS DATA
0xABFA 0xA3
0xABFB 0x01
0xABFC 0x00
0xABFD 0xEE
0xABFE 0x24
0xABFF 0x99
0xAC00 0x3b
0xAC01 0x25
0xAC02 0xd7
0xAC03 0x03
0xAC04 0xEF
0xAC05 0xF9
0xAC06 0x6B
0xAC07 0xA3
0xAC08 0x01
0xAC09 0xF2
0xAC0A 0x1F
0xAC0B 0x38
0xAC0C 0x89
0xAC0D 0x1C
0xAC0E 0x1F
0xAC0F 0x38
0xAC10 0xD7
0xAC11 0x03
0xAC12 0xEF
0xAC13 0x07
0xAC14 0x73
0xAC15 0xF0
0xAC16 0xFF
0xAC17 0xFF
0xAC18 0xFF
0xAC19 0xFF
0xAC1A 0xFF
0xABA6 0xFF
0xABA7 0xFF
0xABA8 0xFF
0xABA9 0xFF
0xABAA 0xFF
0xABAB 0xFF
0xABAC 0xFF
0xABAD 0xFF
0xABAE 0xFF
0xABAF 0xFF
0xABB0 0xFF
0xABB1 0xFF
0xABB2 0xFF
0xABB3 0xFF
0xABB4 0xFF
0xABB5 0xFF
0xABB6 0xFF
0xABB7 0xFF
0xABB8 0xFF
0xABB9 0000
0xABBA 0xFF
ADDRESS DATA
0xABFA 0xA3
0xABFB 0x01
0xABFC 0x00
0xABFD 0xEE
0xABFE 0x24
0xABFF 0x99
0xAC00 0x3b
0xAC01 0x25
0xAC02 0xd7
0xAC03 0x03
0xAC04 0xEF
0xAC05 0xF9
0xAC06 0x6B
0xAC07 0xA3
0xAC08 0x01
0xAC09 0xF2
0xAC0A 0x1F
0xAC0B 0x38
0xAC0C 0x89
0xAC0D 0x1C
0xAC0E 0x1F
0xAC0F 0x38
0xAC10 0xD7
0xAC11 0x03
0xAC12 0xEF
0xAC13 0x07
0xAC14 0x73
0xAC15 0xF0
0xAC16 0xFF
0xAC17 0xFF
0xAC18 0xFF
0xAC19 0xFF
0xAC1A 0xFF
0xABA6 0xFF
0xABA7 0xFF
0xABA8 0xFF
0xABA9 0xFF
0xABAA 0xFF
0xABAB 0xFF
0xABAC 0xFF
0xABAD 0xFF
0xABAE 0xFF
0xABAF 0xFF
0xABB0 0xFF
0xABB1 0xFF
0xABB2 0xFF
0xABB3 0xFF
0xABB4 0xFF
0xABB5 0xFF
0xABB6 0xFF
0xABB7 0xFF
0xABB8 0xFF
0xABB9 0000
0xABBA 0xFF
jamie from oz
not sure how to add a code chunk.
cut and paste i have down tho.
I can msg you my messy MOD HWAD (still adding things )
Ok. I'll have to have a closer look at this, possibly tomorrow.jamie from oz wrote: ↑Wed Oct 26, 2022 4:45 am I think i follow that.
ADDRESS DATA
0xABFA 0xA1
0xABFC 0x00
0xABFD 0xEE
0xABFE 0x24
jamie from oz
Thanks John
jamie from oz
is it possible to add patch code it to the filler between code and data area ??
add code at 0xAF49 or put a call in the console route to a new sub_AF4A ?
af38: 8f,f3,a8,00,28 divw R28,[Rf2+a8] wR28 /= [c41c];
af3d: d5,04 jnv af43 if (OVF = 1) {
af3f: a1,ff,00,28 ldw R28,ff R28 = ff; }
af43: b1,03,2a ldb R2a,3 R2a = 3;
af46: ef,66,87 call 36af Sub_36af (); }
af49: f0 ret return;
af4a -> bfff = 0xff ## fill ##
c000: 74,c3 word c374
c002: 01 byte 1
c003: ff ???
c004: a0,0f word fa0
c006: 5d,01 word 15d
Why does the checksum have to end at 0xffff ?
could we have checksum from 0x2000 to 0xEDFF and when its re calculated it won't see any data from 0xEE00 to 0xFFFF
c002: 01 byte 1
c003: ff ???
Jamie,jamie from oz wrote: ↑Wed Oct 26, 2022 4:45 am I think i follow that.
I didn't proceed past the end of the console route because t thought it will need to be different.Code: Select all
ADDRESS DATA 0xABFA 0xA3 0xABFB 0x01 0xABFC 0x00 0xABFD 0xEE 0xABFE 0x24 0xABFF 0x99 0xAC00 0x3b 0xAC01 0x25 0xAC02 0xd7 0xAC03 0x03 0xAC04 0xEF 0xAC05 0xF9 0xAC06 0x6B 0xAC07 0xA3 0xAC08 0x01 0xAC09 0xF2 0xAC0A 0x1F 0xAC0B 0x38 0xAC0C 0x89 0xAC0D 0x1C 0xAC0E 0x1F 0xAC0F 0x38 0xAC10 0xD7 0xAC11 0x03 0xAC12 0xEF 0xAC13 0x07 0xAC14 0x73 0xAC15 0xF0
I see you have changed the address from D00 to EE00 and written in the rest of the console subroutine as it is from 6DBX.
The purpose of the patchcode is to copy data from uP internal registers to RAM external to the uP.
Checking for a console using EE00 will not allow logging of registers.
The 'Post A Reply' menu bar has an icon with </> on it. Click it and place your code between code and /code.
http://eectuning.org/forums/app.php/hel ... 12d69aa2bd
Yep, I can take a look.I can msg you my messy MOD HWAD (still adding things )
Yes patchcode and payload list can go where ever there is fill space.jamie from oz wrote: ↑Wed Oct 26, 2022 6:32 am is it possible to add patch code it to the filler between code and data area ??
Adding patchcode from AF49 relies on Sub_AEDD to run, it is some way down the Background Vector List and only once. This approach can work but the data refresh is only happening a 1/4 of the time compared to Sub_ABFA. The timing of the data refresh is also much later in the background loop, could be good, could be bad. Timing wise Sub_ABFA is first on the list plus another 3 goes later on, so it has the field covered.add code at 0xAF49 or put a call in the console route to a new sub_AF4A ?
Sure could go with a new Sub_AF4A.
There are a number of ways to execute, your suggestion of Call from Sub_ABFA is one. Another is to Jump from Sub_ABFA.
Both of those methods waste a little uP time due to the stopover at Sub_ABFA.
The direct method is to change the Background Vector List by replacing ABFA with AF4A. I'd change all four entries but it is not essential.
The patchcode is neatest if it fits within the footprint of the Console Subroutine.
I see in your image above that you do not have Tune Position in your QHorse tab, so that can be stripped from the GUFB example for starters.
It doesn't. As posted above yours ends at 0xFFF0.Code: Select all
#### CHECKSUM ADDRESS STRUCTURE a25e: 00,20 word 2000 # Checksum Start Address a260: f0,ff word fff0 # Checksum End Address a262: 00,00 word 0
Yes, but think about word addresses if you make a change.could we have checksum from 0x2000 to 0xEDFF and when its re calculated it won't see any data from 0xEE00 to 0xFFFF
Also ensure the checksum of your new range equals zero and adjust accordingly.
Looking back over the GUFB patchcode, it has code for the payload copying, tune position and handling the remainder of its console routine.
We need the payload copy part.
You have not included the Tune Position in your QHorse tab, so skip that.
The console routine is different in your 6DBX compared to GUFB, so we wont need to handle the much larger remainder.
The payload copying part is short enough to fit in the 6DBX Console Footprint.
The neatest is to overwrite the Console sub, so we'll do that.
You asked about fill space between Code and Calibration data, we'll use that.
We need three scratch registers.
We identified R24 and R38 from the console subroutine.
Looking at R26, it appears to be another scratch register used by background subroutines. We'll try that.
Looking at the disassembled code for the patch;
Vector list is unchanged, though I changed the Sub name in _DIR.
Patchcode overwrites the Console code.
Payload List space from AF50.
DatalogOffset is D00
This is the patchcode that goes in the QHorse tab of the definition.
Also set DatalogOffset to 0D00 in the QHorse tab
Also set Checksum Addresses in the Config tab to match BIN checksum range.
Test it, see what you get.
237c: fa,ab vect abfa SubABFA_Logging_Patch
23b2: fa,ab vect abfa SubABFA_Logging_Patch
23d0: fa,ab vect abfa SubABFA_Logging_Patch
23f4: fa,ab vect abfa SubABFA_Logging_Patch
#### Console Subroutine is now our Logging Patch
SubABFA_Logging_Patch:
abfa: fa di interrupts OFF;
abfb: a1,50,af,38 ldw R38,af50 R38 = af50; # Payload List is at 0xAF50
# JNE Loop from LAC0D until 0x0000 in Payload List SubABFA_Logging_Patch
abff: a2,39,24 ldw R24,[R38++] R24 = [R38++]; # Load Payload Address from Payload List
ac02: a2,24,26 ldw R26,[R24] R26 = [R24]; # Load Data from Payload Address
ac05: c3,25,00,0d,26 stw R26,[R24+d00] [R24+d00] = R26; # Store Data to Payload Address + DatalogOffset
ac0a: 8a,38,00 cmpw R0,[R38] # Test for 0x0000 at end of Payload List
ac0d: d7,f0 jne abff if ([R38] != 0) goto abff;
ac0f: fb ei interrupts ON;
ac10: f0 ret return; # Job done
ac11: ff,ff,ff,ff,ff ??? # Fill Console Sub footprint
#### Fill before Payload List
af4a: ff,ff,ff,ff,ff,ff ???
#### BE uses 0xAF50 to 0xAFB7 as Payload List space
af50: ff byte ff
af51: ff byte ff
af52: ff byte ff
af53: ff byte ff
af54: ff byte ff
af55: ff byte ff
af56: ff byte ff
af57: ff byte ff
af58: ff byte ff
af59: ff byte ff
af5a: ff byte ff
af5b: ff byte ff
af5c: ff byte ff
af5d: ff byte ff
af5e: ff byte ff
af5f: ff byte ff
af60: ff byte ff
af61: ff byte ff
af62: ff byte ff
af63: ff byte ff
af64: ff byte ff
af65: ff byte ff
af66: ff byte ff
af67: ff byte ff
af68: ff byte ff
af69: ff byte ff
af6a: ff byte ff
af6b: ff byte ff
af6c: ff byte ff
af6d: ff byte ff
af6e: ff byte ff
af6f: ff byte ff
af70: ff byte ff
af71: ff byte ff
af72: ff byte ff
af73: ff byte ff
af74: ff byte ff
af75: ff byte ff
af76: ff byte ff
af77: ff byte ff
af78: ff byte ff
af79: ff byte ff
af7a: ff byte ff
af7b: ff byte ff
af7c: ff byte ff
af7d: ff byte ff
af7e: ff byte ff
af7f: ff byte ff
af80: ff byte ff
af81: ff byte ff
af82: ff byte ff
af83: ff byte ff
af84: ff byte ff
af85: ff byte ff
af86: ff byte ff
af87: ff byte ff
af88: ff byte ff
af89: ff byte ff
af8a: ff byte ff
af8b: ff byte ff
af8c: ff byte ff
af8d: ff byte ff
af8e: ff byte ff
af8f: ff byte ff
af90: ff byte ff
af91: ff byte ff
af92: ff byte ff
af93: ff byte ff
af94: ff byte ff
af95: ff byte ff
af96: ff byte ff
af97: ff byte ff
af98: ff byte ff
af99: ff byte ff
af9a: ff byte ff
af9b: ff byte ff
af9c: ff byte ff
af9d: ff byte ff
af9e: ff byte ff
af9f: ff byte ff
afa0: ff byte ff
afa1: ff byte ff
afa2: ff byte ff
afa3: ff byte ff
afa4: ff byte ff
afa5: ff byte ff
afa6: ff byte ff
afa7: ff byte ff
afa8: ff byte ff
afa9: ff byte ff
afaa: ff byte ff
afab: ff byte ff
afac: ff byte ff
afad: ff byte ff
afae: ff byte ff
afaf: ff byte ff
afb0: ff byte ff
afb1: ff byte ff
afb2: ff byte ff
afb3: ff byte ff
afb4: ff byte ff
afb5: ff byte ff
afb6: ff byte ff
afb7: ff byte ff
#### Fill after Payload List
afb8 -> bfff = 0xff ## fill ##
ADDRESS DATA
0xABFA 0xFA
0xABFB 0xA1
0xABFC 0x50
0xABFD 0xAF
0xABFE 0x38
0xABFF 0xA2
0xAC00 0x39
0xAC01 0x24
0xAC02 0xA2
0xAC03 0x24
0xAC04 0x26
0xAC05 0xC3
0xAC06 0x25
0xAC07 0x00
0xAC08 0x0D
0xAC09 0x26
0xAC0A 0x8A
0xAC0B 0x38
0xAC0C 0x00
0xAC0D 0xD7
0xAC0E 0xF0
0xAC0F 0xFB
0xAC10 0xF0
0xAC11 0xFF
0xAC12 0xFF
0xAC13 0xFF
0xAC14 0xFF
0xAC15 0xFF
0xAF50 0000
0xAF51 0xFF
0xAF52 0xFF
0xAF53 0xFF
0xAF54 0xFF
0xAF55 0xFF
0xAF56 0xFF
0xAF57 0xFF
0xAF58 0xFF
0xAF59 0xFF
0xAF5A 0xFF
0xAF5B 0xFF
0xAF5C 0xFF
0xAF5D 0xFF
0xAF5E 0xFF
0xAF5F 0xFF
0xAF60 0xFF
0xAF61 0xFF
0xAF62 0xFF
0xAF63 0xFF
0xAF64 0xFF
0xAF65 0xFF
0xAF66 0xFF
0xAF67 0xFF
0xAF68 0xFF
0xAF69 0xFF
0xAF6A 0xFF
0xAF6B 0xFF
0xAF6C 0xFF
0xAF6D 0xFF
0xAF6E 0xFF
0xAF6F 0xFF
0xAF70 0xFF
0xAF71 0xFF
0xAF72 0xFF
0xAF73 0xFF
0xAF74 0xFF
0xAF75 0xFF
0xAF76 0xFF
0xAF77 0xFF
0xAF78 0xFF
0xAF79 0xFF
0xAF7A 0xFF
0xAF7B 0xFF
0xAF7C 0xFF
0xAF7D 0xFF
0xAF7E 0xFF
0xAF7F 0xFF
0xAF80 0xFF
0xAF81 0xFF
0xAF82 0xFF
0xAF83 0xFF
0xAF84 0xFF
0xAF85 0xFF
0xAF86 0xFF
0xAF87 0xFF
0xAF88 0xFF
0xAF89 0xFF
0xAF8A 0xFF
0xAF8B 0xFF
0xAF8C 0xFF
0xAF8D 0xFF
0xAF8E 0xFF
0xAF8F 0xFF
0xAF90 0xFF
0xAF91 0xFF
0xAF92 0xFF
0xAF93 0xFF
0xAF94 0xFF
0xAF95 0xFF
0xAF96 0xFF
0xAF97 0xFF
0xAF98 0xFF
0xAF99 0xFF
0xAF9A 0xFF
0xAF9B 0xFF
0xAF9C 0xFF
0xAF9D 0xFF
0xAF9E 0xFF
0xAF9F 0xFF
0xAFA0 0xFF
0xAFA1 0xFF
0xAFA2 0xFF
0xAFA3 0xFF
0xAFA4 0xFF
0xAFA5 0xFF
0xAFA6 0xFF
0xAFA7 0xFF
0xAFA8 0xFF
0xAFA9 0xFF
0xAFAA 0xFF
0xAFAB 0xFF
0xAFAC 0xFF
0xAFAD 0xFF
0xAFAE 0xFF
0xAFAF 0xFF
0xAFB0 0xFF
0xAFB1 0xFF
0xAFB2 0xFF
0xAFB3 0xFF
0xAFB4 0xFF
0xAFB5 0xFF
0xAFB6 0xFF
0xAFB7 0xFF
jamie from oz
cool .
I will do that tonight and see what happens.
I should be able to check the checksum number with hex editor nero then adjust / change the 6DBX one at 0x200A before loading BE
thanks John you are a legend!!!
Jamie,
As a baseline it'd be wise to try it on the OEM bin with no changes, allowing BE to do its thing.
jamie from oz
I put patch code into the bin file and loaded it to QH .
key on engine off and limp home mode.
when i try to datalog no data and it changes 0xDFF2 and 0xDFF3 to FF also changes 0xDFFC and 0xDFFD for some reason .
(i am using the 6DBD.bin that i cut/moved the padding to make it start at 0x2000 like SAD_list)
(one row above where it would be in the 0xE000 file so i probably stuffed some conversion)
i will put the patch into a origional 6DBD that starts at 0xE000 and see what happens
Put the patch code into your Definition QHorse tab. Do not edit the bin.jamie from oz wrote: ↑Thu Oct 27, 2022 9:49 pm I put patch code into the bin file and loaded it to QH .
Use an unedited OEM bin to load onto the QH.
Let BE manage the writing of the patchcode to the QH when register payloads are selected for logging.
The bin size and settings in the definition for size and address are all interelated.jamie from oz wrote: ↑Thu Oct 27, 2022 9:49 pm
Post the bin and def if you can't straighten it out.
jamie from oz
these are the ones that match when i do a read in BE through the QH (note they start at 0xE000)
the one after i setup for 5.0v8 and runs ok (note the word at 0xDFFC)
not sure where that comes from and have checked all my addresses but havent found it.
jamie from oz
this is the ones i setup addresses as per SAD and TP with starting address of 0x2000
wont run on this .
wont run on this .
Jamie,
I have a 6DBE EEC here, hardware code ETV-513, to bench test with.
What is the hardware code on your EEC?
Looking at the payload tabs on your defs, only baro pressure needs patch code for logging.
Do you have any others?
MEM expansion does not look to be switched on in the bin, so it is running as single bank.
I'd be inclined to set the def and bin up as 56k to keep it simple.
jamie from oz
yes hardware code ETV-513 (i have a 6DBB and 6DBD so probably just data update in the bin)
i had only put RPM / MAP-BP / ECT ones in and others are just random ones i found to fill the address spots untill i work them out .
when i read it out in BE it always 112K.
with TP i could read it as 256k or 64k.
Yep, just a bin change.
RPM 410 ram address, loggable without patch
ECT 6b2 ram adddress, loggable without patch
MAP, Register address requires patch
Yeah, the ROM chip is larger than 56k so BE reads the whole ROM chip.
Ford put code in one 56k bank of ROM.
Ford set it to run as a single bank as mem_exp is not switched on.
I think address translation could be the issue, so I'll be testing a 56k version first. It may be a couple days before I get time to setup and test.
If you have a harness connector pinout, could you post it up please.
jamie from oz
pin 26 sensor reference 5.0 volts
jamie from oz
this might be better pin out i did as a comparison .
jamie from oz
FYI
with HWAD_E000 runs sweet and in ve table i can lean it out untill it runs rough but no data .
when i use the HWAD_2000 files in the car it dosent like it so i compared it to TI 6dbd and they have the code starting at 22000 (so i looked in the xdf header info and there is a 20000 base offset)
(conclusion it dosent like using the lower part of the ROM)
is there a easy way to offset HWAD_2000 by 20000 in BE ?
Thanks for the pin outs.
Why do you want to offset by 20000 in BE?
6DBX_E000 bin has a mathematically correct checksum.
HWAD2000 bin has an incorrect checksum.
Having looked at your 6DBD bins and those scattered about the web, they have many different checksums, mostly incorrect.
I've taken your def, ignored some stuff, deleted some stuff, changed some stuff, highlighted some stuff and added some stuff. One thing BE gets bent out of shape over is non text in the def, make sure all cells are formatted as text, I changed a lot of number format to text.
The red highlight stuff is very likely incorrect.
The blue highlight stuff, I have added mostly for proof of logging.
I've set it up for 56k as only one bank is active. Further banks are complication for no apparent advantage.
I've run the bin on the bench for hours and logged it now and then. The attached log is the last of the period and has been edited to remove repetitive data. I've applied voltage to some AI channels which can be seen in the log as a change from the pull up values too around 3V. ADC names are based on pinouts provided.
The attached bin and DEF are a matched pair to facilitate the least troublesome register logging experience.
The log is as described above.
The DIR is a copy of your previously posted one with some additions.
It would be wise to test these as they are, as a baseline, before changing stuff.
Test them out as a matched set and see it they work beyond the bench.
jamie from oz
Thank you very much for your time.
I will have a look later today and post the results.
Is there a way I can donate some $ for your time please?
jamie from oz
I loaded them to BE then connected QH and cleared the ram/existing HWAD_E000 tune and uploaded the 56k tune to QH .
when i turned key on it was LHM fuel pump running constant and fans on .
No data when selecting basic or full pid list (probably because of LHM)
it did run about the same as with the 6cyl tune that i started with so there is hope !!!
