Compare tab not updating in BE
Hey. My compare tab only shows the first 4 calibrations i have ever used in BE. I have the latest build of BE2010. Any way to clear them so I can compare some more up to date calibrations or tunes?
Dan
Dan
- 86GT
- BE/EA Developer
Re: Compare tab not updating in BE
yes press compare then hover over the first compare slot and the menu will expand to the left. You can then load a different cal. You can also pres ALT 1 for cal 1 and Alt 2 for cal 2 and so on
Look in the getting started manual to get a list of all of the shortcuts
4.1.2 Compare Binaries
CTRL + 0 = Turns off all compare binaries
CTRL + 1 = Set the compare binary to position 1
CTRL + 2 = Set the compare binary to position 2
CTRL + 3 = Set the compare binary to position 3
CTRL + 4 = Set the compare binary to position 4
ALT + 1 = Loads the compare binary to position 1
ALT + 2 = Loads the compare binary to position 2
ALT + 3 = Loads the compare binary to position 3
ALT + 4 = Loads the compare binary to position 4
4.1.3 Global
ALT + H = Help
ALT + SHIFT + O = Opens the Binary Explorer
A + WRITE button = Writes to all 8 position of Moates Quarterhorse in mode 2
CTRL + D = Binary Difference
CTRL + F = Find
CTRL + I = Customer Info
CTRL + K = Kills off the DataQ process if it is running
CTRL + L = Set USB Latency (default =16) (range 2 - 16)
CTRL + M = Rescan for Moates Devices
CTRL + O = Load Calibration
CTRL + P = Rescan the connected USB devices
CTRL + Q = Show Moates Quaterhorse/Destiny Configuration
CTRL + R = Revision Information
CTRL + S = Save Calibration
CTRL + T = Toggle between Moates and SCT (Only for Burn 1 & 2)
CTRL + ALT + O = Opens a Template
CTRL + ALT + S = Saves a Template
CTRL + SHIFT + O = Load Strategy
4.1.3 Global
ALT + H = Help
CTRL + F = Find
I have tried all of these functions as well as hovering to no avail. Compare only shows me the 4 basic calibrations for CBAZA. This is BE 2012 Build 26. I'd like to be able to browse for a specific calibration.86GT wrote:yes press compare then hover over the first compare slot and the menu will expand to the left. You can then load a different cal. You can also pres ALT 1 for cal 1 and Alt 2 for cal 2 and so on
4.1.3 Global
ALT + H = Help
CTRL + F = Find
The CTRL keys work to set compare tunes, but the ALT keys don't seem to do anything for me.
- 86GT
- BE/EA Developer
I will check this out and if they are broke i will fix it and get it into the new beta
I specifically want the Binary Explorer hot key to work (Alt-Shift-O). More specifically, I just want the ability to apply patch files to tunes even if the Explorer portion isn't there.
- 86GT
- BE/EA Developer
I will take a look at that too. I might enable the bin explorer if the calibration is a BIN and not a BEB
- 86GT
- BE/EA Developer
Send me an email and i will respond with a new build for you to try.
They are .beb files. I'll send an e-mail. Thanks Clint.
The Beta worked and my licenses transferred over as you instructed via e-mail. But after I loaded the Beta and filled the 4 slots on the compare function I could no longer load another file to compare, and there seems to be no way to clear the slots. In other words, I am not able to overwrite any of the compare slots once they were filled. And the "hover" ceased functioning. None of the hot keys work either.
- 86GT
- BE/EA Developer
Some of the shortcuts have changed. This is due to some of the VMs that people use can not use alt key stokes.
4.12.1 Shortcuts
Below is a list of the shortcuts excluding the function and table charts.
4.12.1.1 Tables, Functions, and Scalars
ALT + A = Add the entered value to all selected cells
ALT + D = Divide the entered value by all selected cells
ALT + M = Multiply the entered value by all selected cells
ALT + S = Subtract the entered value from all selected cells
ALT + T = Sets all selected cell to the user entered value
CTRL + A = Selects All
CTRL + C = Copy selected cells into the clipboard
CTRL + V = Paste from the clipboard
CTRL + Z = Set all selected cell to the original values
ALT + = Increases the values of the selected cells by the PID resolution
ALT - = Decreases the values of the selected cells by the PID resolution
CTRL + = Increases the values of the selected cells by the PID resolution *10
CTRL - = Decreases the values of the selected cells by the PID resolution *10
4.12.1.2 Compare Binaries
4.12.1.3 Global
F1 = Help
CTRL + F = Find
4.12.1.4 Data logging
CTRL = Toggle the data log marking value by 1
F5 = Toggles the Data Logging on and off
4.12.1.5 Charts
H = Horizontal Bar Lock
V = Vertical Bar Lock
4.12.1 Shortcuts
4.12.1.3 Global
F1 = Help
CTRL + F = Find
4.12.1.5 Charts
