dynoman
Calcon Freezes during datalog
Post by dynoman » Thu Jan 22, 2004 7:35 pm
I was datalogging today and had the wierdest thing happen.
I started a new log and then accelerated through the gears. I was on it pretty hard and then the car just fell on it's face. I thought I hurt the motor. :cry: . I was able to limp the thing home but it was like it hurt a cylinder or something. When I got home I tried the different positions before shutting the car off and they all seemed to do the same thing except position 5 which made the car died. I noticed the fuel pump was still running after it died. I turned the car off and then back on and everything seems fine. :shock: Now here's the interesting thing.
When I look at the data log in calcon, it goes to a about the first 3 seconds then everything freezes. The sample # and time stamp continue to increase as well as the scrool bar but all the guages and everything is frozen.
When I exported the data, It looks like the computer froze at one single point but calcon just kept logging at that point. all the numbers are the same. Like it got stuck at 3416 RPM and kept that number.
anybody else seen this. I will upload the log to the yahoo files section "dynomanlog.csv
This is a bad bad thing to happen. I don't know if this is becuase of the new sofware or not but this is the only time it has ever happened was when using RT310A87
88GT Vert, 347, Procharger D1 15#boost, 3Core Intercoller, GT40 ported heads and intake 1.6 roller rockers, 75mm Tbody, Pro-M Univermeter, 42# injectors, A9L, 3.73 Gears, Comp Cam 5.56/5.66 Lift 224/232 Dur 114 ctr.
TweecerRT RT1.30A7
Dale McPeters
Professional Tuner/Shop Owner
Post by Dale McPeters » Thu Jan 22, 2004 8:06 pm
Can you list the exact parameters that you were logging at the time?
Also did you build the datalog payload with 1.30A7 or 1.20b3?
It sounds like the payload got hosed...................
Dale McPeters
BE & EEC Analyzer
Paul's EEC-Editor
dynoman
Post by dynoman » Thu Jan 22, 2004 11:03 pm
I'm pretty sure I created the payload with 1.20b. I don't remember ever reseting the payload again before dataloging. I downloaded the file to the yahoo groups files section "dynomanlog" is the name so you can see what I was logging.
Since this post I have re-created my payload with 1.30A and dataloged about 6-7 more times with no problems.
Just hope it doesn't happen again.
TweecerRT RT1.30A7
wkstill
Post by wkstill » Fri Jan 23, 2004 10:07 am
see:
http://tweecer.oplnk.net/viewtopic.php?t=2164
thats the same results..
Gt40x Heads, X303 ValveTrain, E303 Cam., A3M EEC-IV --- SOLD 3/2016
73mm C&L Maf, 65mm TB, 67mm EGR, Power+Plus Typhoon Intake, 24lb/Hr Inj.
1998 4R70W Tranny, Controlled by Bauman TCS, w/Level 3 Bauman Shift Kit, 2400 Edge Racing Stall., 3.73 Trac Lock 8.8 Rear.
