Not sure what's going on. But I use the mongoose to do my loads on my eec v. It's a 1998 cobra Aol3.
I plugged up to it the obd 2 port and USB on the computer and asked be to write to the ecm. It did not detect it and fans and pump were running. This is normally how it starts out for a load. So I power cycled the key to prepare the erase and write. Keep in mind it has not touched the ecm yet. The fans still came on and the pump. So I unplugged the USB and obd2 from the car with the key in the off position. And now the ecm behaves as if it's bricked or erased.
Not sure what happen since the mongoose never wrote or erased anything. Is their an idea of what's happening I need the car so I wrote to an f3 moates to continue driving. The issue makes no sense.
p4ndiamond
Re: Eec v erased
Still no word on this?
p4ndiamond
Re: Eec v erased
another post bump
ironmanisanemic
Re: Eec v erased
had something similar happen to me a few years ago. If it was a software glitch in how BE handled your ECU then Coretuning should make it right. Otherwise if it was an error on your part, you can still flash your ecu, but it will require another token. Hope this helps.
1989 Ford Bronco:
1995 Ford Mustang GT
