latest BE version 5.188 READ from QH shows “0’s”
Hi guys,
Latest BE version has me stumped. When I select READ it will only show zeros for all my values on the QH. I then proceed to WRITE my saved bin back to QH and run the engine and all seems fine. My READ function use to work in the past. Not sure back when with which version though. I normally don’t use READ function much. I want this function to be able to verify if the QH has my bin that I have loaded to it.
Thanks in advance.
Thanks in advance.
1990 LX 5.0 sedan. TFS old school heads. Saleen/vortech intake. Vortech S-trim. TR-3550 trans. C3W1 with QH.
Re: latest BE version 5.188 READ from QH shows “0’s”
Check your version of BE; Current version for public download on the EA website is 5.175 with 5.18 after update. There is no 5.188 that I am aware of.
2003 Mach 1 - Core Tuning RYAK1/ZYA2 QH Tuned, Borla Atak Cat Back, Pypes X-Pipe, Twin 65mm TB, K&N CAI, ICT Billet Intake Spacer, Eibach Pro Series Plus Suspension, Steeda Adj. Upper/Lower Control Arms, QA1 Bump Steer, Steeda Short Throw Shifter, 315/35/17's.
Sorry my mistake. I’m using version 5.180.
No worries, Assuming your version of BE is licensed have tried to read the tune from the QH and compare it to a stock .bin? Have you opened the hardware tab and 1. Enabled the Moates hardware, 2. Checked the QH configuration to see if the tune you wrote to the hardware is whats being represented in the configuration tab, 3. Confirmed your battery back up on the QH is not depleted? If the battery back up has not been changed in a while it could be dead and not retaining the tune you are writing to the QH. If the battery has been compromised, when you open the configuration tab under hardware it will either show your current tune you wrote to the hardware or it will show a bunch of jibberish like ###$87*&*) which means the battery back up is dead and the tune is corrupt; corrupt meaning the hardware cant retain the information if the battery is dead. Just a few things to check.
Just verified everything. Moates is enabled and registered. QH is version 1.6 on mode:4 Tune:2.
I was able to read my tune on the QH that is loaded and it is fine. The question is why can't I read the FORD tune, when I select (Read FORD)? There are a bunch of warning windows that I have to keep clicking OK each time and then once they are completed I have the tune showing all values as "0".
I was sure I could do this before.
That is strange indeed. Ill have to see if I can duplicate your issue on my car later. Ill post what I find.
I just went out and performed a read with no issues or difficulty. Are you performing your read with the key on?
No key in ignition. Just USB to the QH.
Try performing a read with key on.
Finally got some time to try again. FORD READ works with key on.
EDS50 Thank you for your help.
Peter.
Peter.
Your welcome, glad we were able to help you get it figured out.nitrouspete wrote: ↑Tue Sep 17, 2019 7:48 pm Finally got some time to try again. FORD READ works with key on.
Peter.
I think you need to check your BE version. There is some problem with that.
This thread is over a year old. Latest version of BE is 5.217.Loganhannah wrote: ↑Thu Oct 29, 2020 11:53 pm I think you need to check your BE version. There is some problem with that.
