brecht63
Sudden issue opening B.E.
Post by brecht63 » Sat Sep 30, 2023 1:36 pm
So, I used Binary Editor and EA the other night with no issues and then the next night I went to go load my updated tune into my QH and BE wouldn't open. It wont even make it to the loading screen, I just get the windows blue spinning circle for about a second then nothing. So far I've set it to run as admin, opened windows 10 in safe mode, removed and reinstalled BE (a couple times), disabled windows defender (which is my only anti-virus) and tried compatibility mode. EA opens just fine, I would think if Windows 10 was trying to block it for some reason it would also block EA? I'm kind of at a loss here, not sure what else to try. Hopefully someone else has experienced this or something similar and has some ideas.
Update- did a complete reinstall of Windows10, BE began working again, next day same problem after several windows updates downloaded. Issue was found to be caused by Windows Defender thinking BE was a threat, added to exception list and all is well.
89 fox, A3M1, QH, zero decked 5.0 w/flat tops, 58cc TW 170s, TFS stage 1, TFS 1.6 rockers, tmoss cobra, 70mm tb, 80mm maf, 30#, 2 1/2 Mac Pro's w/turn downs, Tremec t5, 3.73s, sn95 brakes and front suspension w/ relocated A arm and rear lower mounts, various M.M. goodies front and rear
