User Defined DataLogging Payloads/snapout dashboard/tracing
BinaryEditor and EEC Analyzer are both packed with awesome features, but if you can think of another cool feature to aide in EEC Tuning or some improvement to an existing feature, cough it up here.
Moderators: cgrey8, EDS50, Jon 94GT, 2Shaker, 86GT
ironmanisanemic
Post by ironmanisanemic » Wed Dec 02, 2015 9:03 pm
Hello,
I am wondering if there would be a way to add the ability to have user defined payloads for datalogging. I saw this ability in EFILive and HP Tuners when i was watching a Greg Banish DVD. This would be handy to have so instead of having to manually jam the logs through your calculator to determine something like fuel error %, you could have it calculate it automatically after you entered your formula and selected what payloads you wanted to use for the calculation, then you would only have to write down the error % and apply the correction quicker.
Also, having a snapout dashboard so you can still see selected payloads in the tuner screen so you dont have to flip back and forth. This would be nice for the above request. Having the fuel error % automatically calculated and displayed so you can look at the maf transfer and know what points to hold at, and what the error % is at that point.
Finally, I know you can "follow the bouncing ball" for tables, but what about adding that ability to functions, Mainly for the maf transfer. Can make it easier to see what maf point your holding if the second item above cant be done.
Thank you.
1989 Ford Bronco:
-393W, Edelbrock Performer RPM heads, ProComp Upper and lower intake, Custom Comp Hyd Roller cam, 10:1 compression, 30lb injectors, 75mm TB, Pro-M 80mm MAF, equal length short tube headers, 2.5 inch y pipe merged into single 3 inch with hooker aerochamber muffler and no cat, QH w/ BE and EA running U4P0, AOD
1995 Ford Mustang GT
ironmanisanemic
Re: User Defined DataLogging Payloads/snapout dashboard/trac
Post by ironmanisanemic » Fri Dec 04, 2015 12:38 am
Nobody has any input?
1989 Ford Bronco:
Post by jsa » Fri Dec 04, 2015 4:27 am
You might be preaching to the converted, it is one C Garrity that must be convinced.
Presently only one PID can have a formula applied. Your excellent suggestion requires at least two PID's as input to a formula.
Post by decipha » Fri Dec 04, 2015 2:53 pm
in tunerpro i have a fuel error gauge on the realtime tuning view, no need in calculating anything just simply look at the gauge in realtime, it doesn't get any easier than that
ironmanisanemic
Post by ironmanisanemic » Fri Dec 04, 2015 3:01 pm
I do like tunerpro, but I'm hoping for improvements to BE. I use both and like both so it would be nice to be able to have similar features in both. Our at least compared to other commercial software out there
1989 Ford Bronco:
