Tuning Marine Ford 351W GT40
Re: Tuning Marine Ford 351W GT40
Post by EDS50 » Thu Jul 20, 2017 5:02 pm
What strategy are you working with?
Tfranscioni
Post by Tfranscioni » Sat Jul 22, 2017 9:29 am
Not a clue what strategy it is.
KirkH
Post by KirkH » Tue Aug 01, 2017 2:22 am
Not a clue what strategy with the crazy bulk it is.
How's the tuning coming along? Still having problems?
Post by jsa » Wed Aug 02, 2017 3:11 am
Tfranscioni wrote:
Thu Jul 20, 2017 1:34 pm
I had trouble getting enough power to the ecm to read it. turns out I had the J3 reader on upside down.
Um, getting enough power to it while the J3 reader is upside down can not be a good thing. It is likely you have let some smoke out :(
I got this read and opened it in the editor. Looks like there is nothing then I scroll down and start to see some code and then continue down and nothing again. I guessing this had to do with where the code is written?
The read is not correct. Maybe you have your address ranges wrong, or you have smoke signals :(
Tfranscioni
Post by Tfranscioni » Sat Aug 19, 2017 9:18 am
Just took this read using a different setting. This "looks" better in binary editor as there is now data showing up in the beginning of the file. What you guys think? I will try and put this read on a Moates F3V2 chip and see what happens.
300M take four.bin
(56 KiB) Downloaded 28 times
Post by jsa » Sun Aug 20, 2017 3:38 am
Take 4 is not a good read either.
Give the attached a try.
300M.bin
Try this
(56 KiB) Downloaded 38 times
Tfranscioni
Post by Tfranscioni » Sun Aug 20, 2017 3:21 pm
Ok thanks I will give this a try! Where did this file come from? Is this my read that you then modified in some way? No questioning it, just curious.
Post by jsa » Sun Aug 20, 2017 9:07 pm
Rehashed your previous read.
Post by decipha » Sat Sep 09, 2017 6:28 am
i killed an ecu many moons ago by hooking the j3 upside down, not fun
welsbat
Post by welsbat » Sat Sep 09, 2017 6:31 am
Hi All,
This thread has been an interesting read. I have the same problem, I just didn't know it!
Is the only hardware than can be used as a replacement EEC the F4FF-12A650-LB? If hypothetically my ECU died what are my options?
Post by jsa » Sat Sep 09, 2017 1:31 pm
That is an engineering part number.
Match up the Hardware codes. If the catchcodes are different use a chip with the right bin loaded.
Tfranscioni
Post by Tfranscioni » Sun Sep 10, 2017 4:41 pm
jsa, your rehash worked! Thank you so much!
Do you mind elaborating on what you changed and what made you realize those changes were needed from my read?
Tfranscioni
Post by Tfranscioni » Mon Sep 11, 2017 10:50 am
If I have sacraficed my original ECU for the sake of this project then that sucks.... The read that jsa rehashed and made work was taken from my ecu after I had done the backwards J3 plug multiple times so luckily I got something usable off of it as it should have been well toasted by that time. Perhaps this thread will morph into me trying to fix my ecu if its in fact toasted. Ill know by next spring when I get my boat project finished up and finally get to put the motor back in and test everything.
Post by jsa » Mon Sep 11, 2017 5:30 pm
You are welcome.
The change was time for me to look at it more.
Time spent disassembling to confirm it was an issue with address range only.
As it is you are still to learn how to read out the factory bin. So compare your read with the rehash in a hex editor. What do you see? Try reading out the bin again until it matches.
Tfranscioni
Post by Tfranscioni » Mon Sep 11, 2017 9:27 pm
Will certainly try and learn something here by spending some time comparing the two reads. Thanks.
Time will tell once I get a chance to try and run the motor but given my read that you rehashed and made work do you have any indication that I have indeed "let some smoke out" of my ecm with my backwards J3 mishap?
Post by jsa » Mon Sep 11, 2017 11:52 pm
No indication one way or the other.
Post by decipha » Sun Sep 17, 2017 9:46 pm
with the j3 hooked backwards you'd usually be unable to communicate on the j3 port, so if you can read the tune out correctly that would hint that its working, chances are its not going to though
Tfranscioni
Post by Tfranscioni » Tue Sep 26, 2017 4:59 am
When I had the J3 backwards I was not able to get a viable read. Once I figured out I had it backwards and corrected it I was able to get a read that fellow poster jsa was able to rehash and the read was put on a Moates chip and it worked when tested using a donor ecm. As to wether or not my factory ecm was destroyed from the backwards J3 mishap I do not know because I have not tried running my engine with it since I started this project. I'm holding onto some hope that because we were able to get a read that worked on the Moates chip then my factory ecm may have survived the backwards J3 debackle.... when I get a chance to test the factory ecm I will post whether or not it works now. Good thing I have a working Moates chip with the tune on it though!
Arynews
Post by Arynews » Thu Apr 12, 2018 3:53 am
michaelbrown
Post by michaelbrown » Mon Apr 16, 2018 5:45 am
Will certainly try and learn something here by spending some time comparing the two reads here with crazy bulk results https://www.fitnessdonkey.com/legal-ste ... ulk-review. Thanks.
So, how's the tuning going along? I am also learning a lot through this platform.
