95gtSTANG
Re: 95gtSTANG's Tuning Diary
Post by 95gtSTANG » Mon Nov 01, 2010 6:09 pm
cougarnut281 wrote:Glad to hear it, I just glanced at the timeslips for the moment and I can tell you right now that most of the difference between run 3 and the others happened between the 60 and 330.
I'll hit up the logs after dinner.
P.S. Your MPH is looking good for a low 13, high 12.
I did notice that most of the difference occured by the 330 ft mark. I will have to look into my launch RPMs-I tried to launch harder than I did before even though I was on street tires. I am still not power shifting either-I am just shifting as quick as I can.
60-330 must still be in first gear so that is interesting-must be my launch I guess.
Wow you think I can get in to high 12s with this combo? I thought I would need at least gears and tires to get there.
TINO,
1995 MUSTANG GT: 306 CUI, Ported TFS heads, Vortech Intake, 75mm TB, 75mm ProM/30lbers, lunati cam, Tremec, Tweecer RT (CBAZA), LC-1, EA/BE
cougarnut281
Post by cougarnut281 » Mon Nov 01, 2010 6:24 pm
Oh yeah, you will need some gear and/or tires to get a 12, I am just saying the mph shows that the engine has the power to do it if you get the rest of the combo right.
95gtSTANG
Post by 95gtSTANG » Mon Nov 08, 2010 7:58 pm
My cursory analysis on the major differences in the last 3 runs:
Well I am not sure if I understand it but these are some of the observations from my last 3 runs, keep in mind run 3 was much faster-
Run 1-Commanded 12.6 Observed AFR 13 Spark 27
Run 2-Commanded 12.6 Observed AFR 13.5 (1st gear) ~13(4th gear) steadily decreased Spark 27
Run 3-Commanded 12.1 Observed AFR 13-12.9 Spark 28
Spark values I am quoting are basically the peak values I saw in the log during the first 2 gears I believe (since my improvement came early in run 3)-so basically I seemed to have run much better with an extra degree of timing and a slightly richer Lambse/AFR. The timing I makes sense but not sure about the richer mixture.
The tunes were the same so I am not exactly sure why the spark changed by a degree and the commanded lambse was much richer. I also did not notice anything compelling about my launch rpms from the 3 runs other than it was obvious I was trying different launch rpms. My shift RPMs were very similar which was interesting because I am not using a shift light. I don't think I rev'd higher than 5500 rpms.
So I still can't explain why my commanded lambse or spark are different in the runs....
TINO,
Post by decipha » Mon Nov 08, 2010 9:33 pm
usually when fueling gets thrown around like that's a failing pump relay fpr filter, or a bad seal from the fpr reference line to the manifold
95gtSTANG
Post by 95gtSTANG » Mon Nov 08, 2010 10:21 pm
decipha wrote:usually when fueling gets thrown around like that's a failing pump relay fpr filter, or a bad seal from the fpr reference line to the manifold
You are going to have to ellaborate on what you mean it doesn't make much sense to me.
TINO,
MikeB
Post by MikeB » Tue Nov 09, 2010 8:14 am
decipha wrote:usually when fueling gets thrown around like that's a failing pump relay, fuel filter, or a bad seal from the fuel pressure regulator reference line to the manifold
95 Cobra- CBAZA/T4MO, TFS 185, Victor EFI, AFM N-91, QH/LC1, FMS 42lb inj, 90mm LMAF, MAC 1 3/4 longtubes, X, race bullets, 4:30's with a coilover/tubular front end, Baseline rear suspension, Draglite big/skinny's! 150 shot of gas coming...
Perfect is the enemy of very good!
Post by decipha » Sat Nov 13, 2010 2:18 am
disregard that i assumed you adjusted your fuel table to demand a richer mix, i missed the part where you stated it did it without user input
probably a function dumping in the excess fuel based off ect, UNLESS you didn't wait for startup enrichment to clear out before you made a pass
95gtSTANG
Post by 95gtSTANG » Sun Nov 14, 2010 10:00 pm
decipha wrote:disregard that i assumed you adjusted your fuel table to demand a richer mix, i missed the part where you stated it did it without user input
probably a function dumping in the excess fuel based off ect, UNLESS you didn't wait for start up enrichment to clear out before you made a pass
There was no enrichment due to ECT- temp never got there. I thought start up enrichment could be likely (car stalled while doing a burnout) but if I understand the timing-most of the time had past for start up enrichment-I assume the timing tables are in seconds?? If I remember correctly start up enrichment could actually explain it-but I think enough time had past?!!??
Soo it looks like no one can explain my extra degree of timing and why the value of my lambses are different :?:
TINO,
87coupe50
Post by 87coupe50 » Mon Nov 15, 2010 2:53 pm
Without looking at the logs (cause I'm at work) I would have to say that you need to look into multipliers/adders/reducers for spark and fuel in regards to ECT and ACT.
edit: looked at your .doc file... ACT starts off around 95* and drops to ~80* at the end of the run. I'll bet their are adders/reducers that are affecting your timing and LAMBSE. check your ECT also.
Dart SHP 363, 190 FAC, Victor 5.0 EFI, 70mm T/B, DBX-97, MSD 6AL, Glenn's 1000HP fuel system, S.D. 60lb'ers, V-2 S-trim - 3.7/6.87 8 rib, TKO 500, Alum D/S, Translock 31 spline, 3:73, S/F connectors, tubular K-member & A-arms, C/C Plates, Coilovers, Strange 10-way, adj. Baseline Susp. street launch, A/C : QH, BE/EA (A9P)
Users browsing this forum: No registered users and 115 guests
