QH/BE Datalog RPM pegged at 16384?
PoweredByAFR185
Post by PoweredByAFR185 » Fri Jan 29, 2016 4:55 pm
Guys, everything works when I data log except for "N-RPM". It is pegged at 16384 and in red. Any ideas? Thanks
1988 Hatch
414w
AFR 225's
Reichard Racing Trick Flow TFS-R 351 air-gapped lower
Trick Flow TFS-R 90mm upper intake
Accufab 90mm tb
CompCams 236XFI hyd. roller cam
MSD 42lb Injectors
Aeromotive rails, A1000 pump, filters, regulator, sumped tank, 8an feed, 6an return
PMAS 95mm lightning MAF
Ford A9P EEC-IV, with Moates Quarterhorse 1.6, loaded with GUFB/A9L modified tune
Tremec 3550/TKO; Pro 5.0 shifter
Kooks 1-7/8'' longtubes
3'' H-pipe'd exhaust, Flowmaster Super 44's, dumped
LeadHead
Re: QH/BE Datalog RPM pegged at 16384?
Post by LeadHead » Mon Feb 08, 2016 2:29 am
What definition?
Fleckster87
Post by Fleckster87 » Sat Mar 12, 2016 9:31 pm
I had this issue make sure that your using the right tune on the quaterhorse.
Post by EDS50 » Sun Mar 13, 2016 8:12 am
Make sure the gauge is configured properly.
POPSRACING
Professional Tuner/Shop Owner
Post by POPSRACING » Sun Mar 13, 2016 12:20 pm
Noise from ignition stem, bad dizzy possibly.
Land and Sea chassis dyno
1995 Cobra, 408, sold...
Post by EDS50 » Sun Mar 13, 2016 1:47 pm
Also make sure it is included in your payload as a datalogable pid. How does it display on your BE dashboard?
POPSRACING
Post by POPSRACING » Sat Mar 26, 2016 8:58 am
PoweredByAFR185 did you get this resolved.
