Stock values for CTBAE
daet1234
Post by daet1234 » Mon Mar 14, 2016 1:12 pm
If anyone has a stock CTBAE (5.0 Explorer) bin, I sure could use some info:
Injector high/low/bkpt (ALOSL,AHISL,FUEL_BKPT)
Borderline spark table (FN 2200)
MAF transfer (FN 036)
load scaling (FN 035)
Crank PW (FN 348A)
Thanks in advance.
1981 Fairtang or Musmont: Fairmont wagon and mustang amalgamation.
strat CDNA4 using deciphas zxa5 base. Tuning with Quarterhorse, Binary Editor, and EEC analyzer.
5.0 fuel injected, DIS, GT40 heads, GT40 intake, 19lbs/h injectors, 65mm throttle body, exhaust: long tube headers to 3" collector sized down to 2.5 dual with Xpipe, Mellings HV oil pump, stock form engine from 97 Exploder mated to a Tremec 3550.
Re: Stock values for CTBAE
Post by decipha » Mon Mar 14, 2016 1:25 pm
from the SLL4 bin
SLOPE HIGH 19.405
LOW 21.492
CIDSEL CID TYPE 0
CID 301.983
HSFAN 1
LSFAN 0
4X4 0
EGR 0
VSTYPE 1
ACPSEN_HP 0 AC PRESSURE SENSOR SW
DUAL WIND FAN 1
FP DRIVER 0
FP TYPE 0
MAN VOL 4.5
MAF TRANSFER
5 932.46
4.75 786.76
4.5 671.34
4.25 561.99
4 496.64
3.8 440.49
3.6 377.26
3.4 328.74
3.2 282.62
3 237.36
2.8 197.75
2.6 161.82
2.4 130.7
2.2 106.66
2.1 94.632
2 84.872
1.9 76.243
1.8 66.907
1.7 59.269
1.6 52.055
1.5 45.972
1.3 35.505
1.2 30.554
1 22.491
.9384 20.511
.80 15.56
.60 6.3654
0 6.3654
0 6.3654
CRANK PW
180 2.63
150 3
100 5.49
70 8.49
40 14
20 24
0 39
-20 58
INJ OFFSET
16 .531
15 .531
13 718
12 .843
10 1.156
7 2.375
0 2.375
daet1234
Post by daet1234 » Mon Mar 14, 2016 7:36 pm
Thanks a ton. Time to get back to work.
ironmanisanemic
Post by ironmanisanemic » Mon Mar 14, 2016 11:30 pm
daet1234 wrote:If anyone has a stock CTBAE (5.0 Explorer) bin, I sure could use some info:
Crank PW (FN 348A)
Thanks in advance.
here are the other things decipha forgot to give you that you asked for:
breakpoint - 0.00001034
borderline spark table - Image
load scaling -
16384	0.73
5000	0.73
4000	0.79
3000	0.73
2000	0.69
1000	0.65
0	0.63
hope this helps
1989 Ford Bronco:
1995 Ford Mustang GT
POPSRACING
Professional Tuner/Shop Owner
Post by POPSRACING » Sat Mar 26, 2016 9:02 am
Just open Core Tuning tune the open template attached and it will import the injector values.
CTBAE SLL4 Inj template.zip
(2.19 KiB) Downloaded 61 times
Land and Sea chassis dyno
1995 Cobra, 408, sold...
daet1234
Post by daet1234 » Sat Mar 26, 2016 11:39 pm
Thanks again for all the replies. I have got it running so much better now. It feels more stable and it smells leaner (I learned from older mechanics).
The only thing I wasn't able to understand was the borderline spark table. I am not sure if I need to scale to 200 or calculate linearly.
Post by decipha » Sun Mar 27, 2016 12:51 am
the borderline spark table has quite a few a multipliers the values itself is absolutely useless, a value of 60 could return less spark than a value of 10 it just depends on the multipliers, thats why i didnt post it
daet1234
Post by daet1234 » Sun Mar 27, 2016 10:07 am
I see; still learning. I was still trying to get some sort of baseline. So with the other information, this is where I start.
That MAF transfer was driving me nuts! Alright, back to the grind.
Post by decipha » Sun Mar 27, 2016 10:35 am
if you follow the instructions in the zxa5 your timing will be taken care of
with timing simplified such as in the zxa5 your borderline spark table will be the actual spark you receive, if you plug in 50 you will get 50 unlike all stock tunes
