Does anybody have a CQAB1 def file for BE?
Post by cgrey8 » Tue Sep 06, 2016 7:39 pm
I wanted to open the XDT2.bin file (97 Explorer 5.0L) posted on the eecanalyzer.net website, but my VERY old copy of sailorbob's CQAB1 cry file doesn't seem to work with the latest BE. It throws errors. It used to work, but doesn't seem to anymore. So does anybody have a CQAB1 xls or cry that will show me at least MAF & Injector Parameters?
ironmanisanemic
Re: Does anybody have a CQAB1 def file for BE?
Post by ironmanisanemic » Tue Sep 06, 2016 10:18 pm
do you just want to see the maf and injector params or is this something your trying to tune?
If the first here ya go:
MAF Curve
5.00	1041.2813
5.00	1041.2813
4.75	882.8719
4.50	757.2566
4.25	615.9572
4.00	531.6908
3.80	464.9621
3.60	391.5320
3.40	336.6377
3.20	284.5950
3.00	239.1111
2.80	199.9009
2.60	164.1127
2.40	133.3148
2.20	106.5093
2.10	97.0988
2.00	86.9754
1.90	77.7076
1.80	69.8655
1.70	62.5938
1.60	54.1814
1.50	47.1949
1.40	40.9212
1.30	36.5012
1.20	30.5127
1.00	22.3855
0.94	19.2487
0.80	16.1118
0.60	10.1234
0.00	6.5588
Injector parameters
Fuel Injector Breakpoint	0.00001034
Fuel Injector Minimum PW	0.49972534
High Slope Fuel Injector Spec	19.405
Low Slope Fuel Injector Spec	21.492
injector offset
15.94	0.5313
15.00	0.5313
13.00	0.7188
12.00	0.8438
10.00	1.1563
7.00	2.3750
0.00	2.3750
0.00	2.3750
0.00	2.3750
0.00	2.3750
0.00	2.3750
0.00	2.3750
1989 Ford Bronco:
1995 Ford Mustang GT
Post by cgrey8 » Wed Sep 07, 2016 5:27 am
That's all I wanted. A guy in a different thread was asking me for my empirically found Injector parameters for the 19lb EV6 style injectors with EV1 connectors that come on 96-97 Explorers. I suggested he start with these values. He's using a C&L 73mm, but I've wanted the Explorer MAF in the past so I was wanting access to that.
But now that I know its here in the forum, no need for the def file anymore.
It might be nice to have a spark table posted here as well...just as a starting point for people using GT40p heads with the Explorer cam.
Post by decipha » Wed Sep 07, 2016 8:40 pm
it takes about half a day solid to manually cross calculate a final spark table
good luck with that
Post by cgrey8 » Thu Sep 08, 2016 4:54 pm
decipha wrote:it takes about half a day solid to manually cross calculate a final spark table...
Isn't there an excel spreadsheet that could help with that?
Post by decipha » Thu Sep 08, 2016 8:48 pm
if someone created one, none exist to my knowledge
it would be significantly less time consuming to create a program that just sucked the variables out the bin and ran it through though
89mustangnotch
Post by 89mustangnotch » Mon Jun 26, 2017 1:07 am
Anyone come up with anything better or closer than the a9l2 for spark tables for gt40p heads. I was running 15 degrees at wot and I changed it to 22 made a huge difference in car. Trying to find that right timing during load above 90s for boost up to 10 psi max.
89 coupe 302 eagle I-beams, sealed power pistons, gt40p heads, Anderson n-21 cam , 1.7 crane rockers, professional products typhoon intake, BBK 75mm TB, 3" pmas hpx-e maf, 60lb dekas, moates QH with tuner pro vortech v1 s-trim intercooled. Stock t-5, spec clutch,35 spline strange axles and full spool, 4:10 gears, c clip eliminators,BBK shorty headers, BBK x-pipe to flowmasters, EGR,Smog, AC, PS, deleted. Sitting on MT 28x10.50 stock tubs.
Post by decipha » Mon Jun 26, 2017 4:58 am
im sure it does, 22 degrees is ALOT for a boosted gt40p setup with 10lbs, not knowing anything about your setup I'd recommend about 19 or so for safety
just be sure to read your plugs and run good fuel
89mustangnotch
Post by 89mustangnotch » Mon Jun 04, 2018 1:42 am
can you post that spark table for the explorer thanks.
POPSRACING
Professional Tuner/Shop Owner
Post by POPSRACING » Wed Jun 13, 2018 3:16 pm
CQAB1 has been available for some time
Land and Sea chassis dyno
1995 Cobra, 408, sold...
