New to tuning trying to learn what to do
skunkworks
Post by skunkworks » Fri Mar 17, 2017 5:32 pm
You guys helped me with the donor car that i found the quarterhorse in i thought i would buy one in try it in my own car.
My car is alot of old donated parts and stuff people didn't want anymore so.I have it running on the stock a9l tune file and it runs just like it always has which was never that great so here is my combo .
stock bottom end 302
gt40 iron heads
explorer intake
bbk long tubes
30# venom injectors (old as dirt couldnt tell you where they came from )
grantatelli motorsports 90 mm maf meter for 30# injectors
unknown camshaft its an anderson motorsports cam no idea the specs it was given to me from a friend who had it in a engine that he parted out (possible b-41cam sounds really good )
70 mm t body and egr spacer
timing is set at 12 degrees
fuel pressure is at 39 psi
The car is a mutt it has 82 gt nose body is an 88 all the wiring and interior is 92 gt with air bag
has sn95 brakes 3.73 gear with aburn pro (donated rear from totaled car)
So there the combo and here is the problem i have as it sits like it alway has its very rich at idle i have aem wide band and she pegs at idle.
I looked up some things to help and iam at a little loss. I dont see these injector listed or the maf so
i just need pointed in the right direction thanks for the help and please excuse my stupidity at times iam learning
bocam1
Re: New to tuning trying to learn what to do
Post by bocam1 » Thu Jun 27, 2019 4:32 pm
Following
85 Mustang Coupe, 92 drivetrain, Professional Products Upper and lower, long tubes, PA AOD, Moates Qhorse, C&L,Nitrous Works Nitrous Kit, Stock heads, cam, and internals. Best quarter mile with stock everything and a bottle was 12.09 at 114 MPH on MT Sportsman Pros.
Post by motorhead1991 » Fri Jul 12, 2019 4:46 pm
You don't need to bother with calibrated MAFs if you have the ability to tune...
Anyways, I would first increase the low slope a bit (say 15% increments) and see how the car responds. If that works but it doesn't drive well, pull it out of the MAF transfer instead.
Users browsing this forum: No registered users and 42 guests
