Cbaza turbo inferred load
Stevenmverrill
Post by Stevenmverrill » Wed Feb 28, 2018 8:20 am
So I had a scary moment. Must not of clipped the maf in all the way and it came undone. I did not notice, did a wot. Pull and and a:f jumped up to 15:1..
I since changed all the load in areas boost is possible to a little higher then what is possible. Ie: wot. From 2k and up set to 180 and and 150 at 3/4 throttle from 2k and up.
I'm wondering if this is a good solution or, will it affect fueling even when the maf is working and I should get it close?
I do like the idea of having it so I can get it home if the maf fails but don't want the possibility of going lean in boost
Thanks for any input.
