Lucas injectors missing data
FinnCobra
Post by FinnCobra » Tue May 22, 2018 2:10 pm
I'm having hard time to adjust injector values. They are Lucas D1720BA 30 Lbs. I did't find anything but the nominal value. I tried to use Ford injector or ProM 30 lbs values. I have adjusted cranking pw values, that engine starts without throttle. After cranking, idle bumps little and then stalls. After 30 secs it will idle. In open loop car works decently, lambse matches wideband. Closed loop will adjust afr too lean. Is the voltage offset critical for startup and warming?
Ford Mustang Cobra -94 Mach + Eaton swap in progress. Ford Fiesta ST150
BMW F650GS with Power Commander
