How to adjust Ymax value for MAF range in BE?
canuck1
Post by canuck1 » Wed Jun 05, 2019 4:35 pm
I have a high flow MAF that is rated as 2352 Kg/hr at 5.0v +. I've put my transfer function values in but the max flow values are still below what my MAF is rated for. Where do I go to adjust this value?
Sean
Factory 5 roadster
351w based 396 c.i. stroker. Mass-Flo-EFI style intake w 46lb Pico injectors, AFR 195CC Renegade heads, Comp XE274HR, 10.4:1 CR, custom long tube headers and sidepipes. 5spd manual trans, 3.73:1 rear.
A9L ECM E9ZF-12A650-A2A with Moates F3 chip
Re: How to adjust Ymax value for MAF range in BE?
Post by motorhead1991 » Wed Jun 05, 2019 6:08 pm
ECU is clipped the maximum value. Scale your displacement and injectors instead
canuck1
Post by canuck1 » Thu Jun 06, 2019 2:46 pm
Are these my scaling steps or is there more to do:
1. Scale engine displacement
2. Scale injector low slope (ALOSL)
3. Scale injector high slope (AHISL)
4. Scale FUEL_BRKPT (FN389)
5. Scale MAF transfer functions (FN036)
6. Scale FN1358 (all cells in bottom 3 rows)
7. Scale FN1036A (all cells)
I am struggling to understand the changes I need to make to spark table or perload! Is there anyone willing to provide a simple description?
Sean
Factory 5 roadster
Post by motorhead1991 » Thu Jun 06, 2019 6:46 pm
Sean
Looks correct, and you don't have to touch the tables.. by rescaling, you are adjusting how the computer calculates load. You can adjust it until the load numbers follow something recognizable and it will still correlate to the tables correctly.
Users browsing this forum: Trogdor and 18 guests
