GUFB lambse not following OL table
95GTSpeedDemon
Post by 95GTSpeedDemon » Tue Sep 17, 2019 7:37 am
Cold start [90*f], lambse is around 12.5afr for a bit then leans out slowly. Issue is, i have zeroed out the fuel startup enrichment & targeted stoich, and forced OL idle w/ the closed throttle timer and its targeting richer than i set it to. Ideas?
Re: GUFB lambse not following OL table
Post by cgrey8 » Tue Sep 17, 2019 7:53 am
I'm not sure, but if you post the tune that's reproducing this, it'll be a lot easier to figure out than guessing as to what it might be.
95GTSpeedDemon
Post by 95GTSpeedDemon » Tue Sep 17, 2019 8:00 am
That is true! Lol
davidhuther_93oct-v4.bin
(56 KiB) Downloaded 29 times
davidhuther_93oct-v4-cold-idle.csv
(1.99 MiB) Downloaded 27 times
Post by cgrey8 » Tue Sep 17, 2019 9:10 am
I'm at work, but I'll do my best to remember to look at this when I get home tonight.
Or perhaps someone else will take a look at it and chime in as to what the likely problem is.
95GTSpeedDemon
Post by 95GTSpeedDemon » Tue Sep 17, 2019 5:52 pm
tried again, runs rich at start up. i found its not going lower than my lowest afr scaler set now since i nulled the multipliers. now i need to see why its not commanding 14.6afr. the stock min afr setting of 10.x explains the black smoke that was seen. now its just not *as* bad.
davidhuther_93oct v6 2019_Sep_17_17-41-17.csv
(690.15 KiB) Downloaded 23 times
davidhuther_93oct v6.BIN
(56 KiB) Downloaded 30 times
Post by cgrey8 » Tue Sep 17, 2019 7:31 pm
My guess is it's FN308. Try flattening it out and see if that changes things.
95GTSpeedDemon
Post by 95GTSpeedDemon » Fri Sep 20, 2019 6:57 pm
that may have helped but it wasnt 100% the fix. i found since i didnt use LOLOD to command OL fuel at CT only and i didnt set the NIOLD & NIHYS correctly, it went back to CL fuel... which the lumpy cam causes a lean reading... bang, the eec throws fuel at it. (swapping the NIOLD/NIHYS values actually fixed it, stays in OL @ Closed Throttle now).
thank you for your help!
95GTSpeedDemon
Post by 95GTSpeedDemon » Sat Sep 21, 2019 12:38 pm
AAAANNNNDDDDD... i was wrong. threw its self back into CL while it was cold... :headbang:
