Can someone please try to explain the adaptive fuel air flow table for me, I'm confused.
My table has a few rows with some positive numbers and most are -99.
All the columns are 6000. I've read the explanation but am very confused with these numbers.
Can you explain what this means?
Thank you
Adaptive Fuel Table Air Flow - need help
66 Mustang. 1988 5.0 block, 2000 GT40P explorer heads, 10.5 hyper pistons, Ford F cam, hyd roller lifters and rockers, 1998 Explorer EDS2 ecu running RAAD4, 1998 Explorer fuel injection and coil packs, AODE/W trans. Moates QH, BE, EA
Re: Adaptive Fuel Table Air Flow - need help
Appears to be a corrupt file/.bin or strategy or combination of the both with those values.
2003 Mach 1 - Core Tuning RYAK1/ZYA2 QH Tuned, Borla Atak Cat Back, Pypes X-Pipe, Twin 65mm TB, K&N CAI, ICT Billet Intake Spacer, Eibach Pro Series Plus Suspension, Steeda Adj. Upper/Lower Control Arms, QA1 Bump Steer, Steeda Short Throw Shifter, 315/35/17's.
were you able to find a solution?
When using airflow in this table only the first 2 columns are used which I believe is how the explorers were set up. First column is bank 1 and second column is bank 2. The numbers represent how fast KAMRFs update. The first 4 columns in the top row is reserved for idle in and out of gear with A/C on or off. The rest of the table is not used. If you switch it to use load then negative numbers point to other cells.
2002 F150 Harley Davidson, Supercharged 5.4L, EKO1/OMAE1, 11:1 compression, Comp XE274H cams, ID1050 injectors, DW100 and DW400 pumps, BA2600, Jokerz ported blower, FI Interchiller, Trick Turbo intercooler, Circle D 2800 Stall, too much more.
Users browsing this forum: No registered users and 27 guests
