TURBO COUPE
LA3_SD.BIN correct XDF file?
Post by TURBO COUPE » Mon May 31, 2021 7:43 am
Trying to open the LA3_SD.BIN file with the T23B.XDF but everything is all over the place and doesnt make sense. I can open a stock LA3 bin with the T23B xdf after modifying the bin size and base offset but no matter what i do i cant get the la3 sd bin to make sense. Could anyone help me with that? It would be greatly appreciated.
Re: LA3_SD.BIN correct XDF file?
Post by tvrfan » Mon May 31, 2021 3:04 pm
In case it helps any, LA3 is one of my 'test set' of bins for my disassembler. Although not perfect yet, it does produce a useful listing of code and most of the data structures. Unfortunately it cannot tell you what each actual data structure does, but I have attached the listing and message file (which gives commands, so tells you what is where) in case this helps you sort it out.
la3.zip
(87.43 KiB) Downloaded 216 times
TURBO COUPE
Post by TURBO COUPE » Tue Jun 01, 2021 1:03 pm
Ok thank you ill check it out. I attached the two files in case anyone wants to look at or play with it. I am hoping to find someone firmilar with this bin and ecm. I just ordered an F3 and Jaybird earlier today trying to get it figured out before a track outting tomorrow.
LA3_SD.bin
(56 KiB) Downloaded 231 times
T23B.xdf
(257.38 KiB) Downloaded 255 times
skunk
Post by skunk » Wed Jun 02, 2021 12:34 pm
You won't be able to use that definition for the speed density bin. It missing the extra parameters you need.
If you compare the SD bin to a stock bin you will see a shit tonne of extra code.
1987 Turbocoupe.
A3M1/A9L, BE/EA, Tweecer RT.
skunk
Post by skunk » Wed Jun 02, 2021 1:23 pm
https://eectuning.org/forums/download/file.php?id=4606
Try the definition file I posted in the above thread. I believe it has all the MAF and SD parameters. Unfortunately it's written for BE and might not open properly in TunerPro.
1987 Turbocoupe.
TURBO COUPE
Post by TURBO COUPE » Wed Jun 02, 2021 6:43 pm
Thank you, I will most likely be purchasing BE anyway so then Ill be able to take a look
oharris
Post by oharris » Mon Aug 02, 2021 10:00 pm
I tried all kinds of things trying to get an xdf that would work with the SD bin. Never did get it to work.
Post by EDS50 » Tue Aug 03, 2021 12:31 pm
ADX/XDF are intended for use with tunerpro. DEF/BIN are intended for use with BE. They can not be intermixed from my understanding.
2003 Mach 1 - Core Tuning RYAK1/ZYA2 QH Tuned, Borla Atak Cat Back, Pypes X-Pipe, Twin 65mm TB, K&N CAI, ICT Billet Intake Spacer, Eibach Pro Series Plus Suspension, Steeda Adj. Upper/Lower Control Arms, QA1 Bump Steer, Steeda Short Throw Shifter, 315/35/17's.
oharris
Post by oharris » Tue Aug 03, 2021 1:13 pm
The ADX file is what I could never find.
Post by EDS50 » Tue Aug 03, 2021 1:25 pm
oharris wrote: Tue Aug 03, 2021 1:13 pm The ADX file is what I could never find.
That may be a tough one to find. Ive never seen one but havent looked too hard either.
Post by motorhead1991 » Tue Jan 18, 2022 11:20 pm
EDS50 wrote: Tue Aug 03, 2021 1:25 pm
I was working on adapting Deciphas universal ADX to LA3 but I don't have one on the bench to confirm my testing.
