Rocketengines
Will you still get a FPDM code if properly deleted?
I am having issues with a 04 cobra motor i installed in a 56 f-100. I had the 2 ecm done by 2 different tuners, PATS deleted, emmission deleted and set up for return style fuel system, but i still get "No FPDM" codes and evap codes, should I? Also the engine runs but drops 500-600 rpm and recovers every 4-6 seconds. A/C compressor and low fan relays also cycle even though the High side and low side sensors are not hooked up. I am using the factory ecm and engine harness and have checked every wire for short/grounding. and have no other codes. 25 years as a ASE master tech, but only Harley Davidson performance programming experience. Please help.
Users browsing this forum: No registered users and 160 guests
