OzFalcon
Lean cruise (MFA) (MPG) mode not switching on sometimes
Post by OzFalcon » Sun Apr 09, 2023 8:23 am
hi guys, im having an issue where the car wont go into lean cruise consistently..
i am running a stock tune WANA australian 6cyl 4.0 falcon..
it usually goes into lean cruise when cruising but on the last couple of long hwy drives it has refused to enter..
i am monitoring it using a windband and can see when it does/doesnt.. afr will drop down to near 1.3 Lamda when in lean cruise..
i am wondering what does the ecu look for to decide when to activate the MFA mode..
is it time? time since what?.. is it temperature?.. i know it limits it by RPM and load as it will jump out when u put your foot down..
i thought it might be temperature related.. i have noticed the temp sits around 86 (Celsius) when cruising at 100kph.. the other night though the temp was moving between 82-87 fairly rapidly making me think the thermostat might be too cool and perhaps affecting things..
i know it isnt something that most people care about but some might find it interesting and know how it all works or can point me in a direction to find an answer..
Primary car : 1999 Falcon AU 1.5 australian 6cyl
ECU : EEC-V
WANA / 9XL1N6
EDIS with Speed Density
Using TunerPro / Quarterhorse
from Vic, Australia
xd41efisc
Re: Lean cruise (MFA) (MPG) mode not switching on sometimes
Post by xd41efisc » Sun Apr 09, 2023 6:55 pm
I don't know if AU is the same, but I have read that EL needs the power steering pressure switch to be working properly to enable MFA.
OzFalcon
Post by OzFalcon » Sun Apr 09, 2023 8:23 pm
xd41efisc wrote: Sun Apr 09, 2023 6:55 pm I don't know if AU is the same, but I have read that EL needs the power steering pressure switch to be working properly to enable MFA.
nope i havent heard that.. cant see how that would tie into it..
ECU : EEC-V
WANA / 9XL1N6
from Vic, Australia
Users browsing this forum: No registered users and 59 guests
